professor_jonny
- Joined
- May 26, 2023
- Messages
- 4
- Likes
- 1
HI I have an a speaker and it has a screw in compression driver in the top that is 65mm in diameter and very close to the top of th enclosure and wont fit any thing with a bigger diameter.
It seems all drivers with simular dimentions are rated at 20-40w max and they are junky looking and the original driver is super expensive and very prone to failure, most people seem to block of the horn and screw a standard driver to the front of the horn it seems (hack job)
I'm wondering if there is a 90 degree manifold that I could buy or make to adapt a larger diameter driver i see there is y adaptors for twin drivers but i have not come across an elbow?
I can weld up something but im unsure if it would effect the sound output or not.
