JP
It saves a png of the plot when you run it. Not sure what you mean re: scale?
I just need to waste my time a bit and learn some Python as well.But why is W&F is a thing in the 21st century?
Ah.It should save it, but I don't find it in the home dir.
Scale; it sets the scale to max frequency, e.g. 1001.26 and then ticks it from that, 1000,26, 999,26. Would be nice to have ticks/scale at integers. 1002, 1001, 1000...
Yes, I would probably just use 1 or 3 kHz signals. But the test records are just too flawed. Also the Denon XG-7001 which just arrived was disappointing.Of course the labels won't make sense if you go below 1Hz/tick.
I know there is a 4.16 Hz component (slightly skewed motor shaft) but I am not sure if it is visible here. There might be a pattern as you say, but difficult to say what the origin is.There looks to be a pattern of wow that correlates on all the records, though to differing degrees.
