Blink Too Fast
- Joined
- Jun 1, 2023
- Messages
- 43
- Likes
- 28
Received my BRU5 today (New Jersey, USA). Ordered 8 days ago on AliExpress, including a weekend and Christmas.
I paired it with a 48v 5A power supply.
I am an existing REW software user, and am comfortable using this for time alignment and PEQs.
I used the ACPWorkbench software on the AliExpress item page. At time of writing, this was ver 2.24.2. Link
I also used a version of the software I found linked on Reddit. At time of writing, this was ver 2.33.0. Link
Both installed without issue. Both worked. v2.33.0 is a little more polished, but had similar functionality.
The only functionality I wanted was the EQ.
Ran REW; measured with a UMIK-1 mic; pressed EQ; typed the f, G, & Q settings for each filter from REW to ACPWorkbench.
Also added a high-pass filter at 24Hz to offer at least some speaker protection
Done. It worked as intended.
Pressed "Downloader" > "Save Configuration to Flash"
I since watched the Wondom video that says not to overwite PEQ0 or PEQ1, so I may or may not reset to factory and use PEQ2-PEQ9 instead.
There are 20 PEQs (10 PEQs on the preamp, and 10 PEQs on the poweramp)
Right and Left channel EQs are linked. I do not see a way of setting them independently in 2.24.2 or 2.33.0.
It is possible to increase the preamp and poweramp gains in the software. I did to experiment, then returned them to zero.
When bluetooth is connected, and volume dial full, I can hear a hiss about 18" from the speakers. For comparison, I also have Fosi V3 which has hiss at 3", and Topping PA7, which has no hiss with my ear touching the tweeter.
When bluetooth is not connected, and volume dial full, there is an ethereal sound that can be heard throughout the room when music is not playing. This can be removed in the software by setting [music noise suppressor 0x81] > [Ratio 4; Threshold -62dB; Attack 1ms; Release 100ms]. At first listen, I cannot hear it impact the music.
I tested with modified Zenith Circle of Sound Z565 speakers, which have a strong colouration, REW, and a UMIK-1 mic.
Chart shows before and after. It works.
Chart shows thumbnail of the 1x highpass and 9x PEQ settings used for the REW screenshot above.
