Vini darko
Thankyou for the reply @JohnYang1997 I'm still new to in depth measurements and have much to learn.
Thank you!Can we get a pic of the back?
What "channel imbalance" are you referring to?Outstanding performance regardless of price, and at its target price point... unbelievable! Exceptional work @JohnYang1997, when you first announced your intention to develop these amps with Topping, I was skeptical, but the proof is in the pudding! Hopefully the channel imbalance issue is limited to this pre-production unit, as that would be a truly unfortunate blemish on what is otherwise an essentially flawless performance! There aren’t enough superlatives to express what you’ve achieved here, you should be extremely proud, and I’m excited to see what the future holds for you.
The one mentioned on the first post?What "channel imbalance" are you referring to?
That one: https://www.audiosciencereview.com/forum/index.php?attachments/rms-level-jpg.70140/What "channel imbalance" are you referring to?
@ichonderoga yes, the dotted blue line is the difference in levels between the left and right channels while the red and blue line is the volume button decreasing the levels. It means that only the first 9 decibels of attenuation the channels are somewhat attenuated the same (Y axis left the red and blue decreased 9dB, Y axis right the dotted blue differ 0.5 decibel, which is somewhat the tolerable limit).
The channel balance... barely makes sense... I will update the data of other units.
While the result is technically superior I just can't get onboard with feel of a clicky stepped knob over a smooth pot. Relay attenuators even worse from a user experience for me, very disruptive to critical listening. I'd argue that a very good mechanically designed rotary encoder + well implemented digital volume control is best.Topping should make a stepped attenuator edition of L30 and A90.
Why is a channel imbalance at low volume usually expected for a pot? Does the imbalance at low volumes have something to do with the wiper mechanism?View attachment 70224
This a spec sheet for a £40 high quality pot. Even it has expected imbalance. Its just a part of this type of component. Only a stepped attenuator or digital volume are gonna be close to perfect.
I think it has to do with the carbon tracks and how they are laid down.Why is a channel imbalance at low volume usually expected for a pot? Does the imbalance at low volumes have something to do with the wiper mechanism?
Same pot is used for a90 and l30. This must be an outlier.Outstanding performance regardless of price, and at its target price point... unbelievable! Exceptional work @JohnYang1997, when you first announced your intention to develop these amps with Topping, I was skeptical, but the proof is in the pudding! Hopefully the channel imbalance issue is limited to this pre-production unit, as that would be a truly unfortunate blemish on what is otherwise an essentially flawless performance! There aren’t enough superlatives to express what you’ve achieved here, you should be extremely proud, and I’m excited to see what the future holds for you.
The imbalance between the left and right channels of D90 and L30 has a problem in selecting the volume POT.Same pot is used for a90 and l30. This must be an outlier.
