WolfX700 Measurement of Topping L30 Headphone Amp
MoveJoe
Just ordered from Shenzhenaudio. Can't wait for it to arrive.
Any recommendations for RCA cables to connect the E30 and L30? I found these from the UK that look fine to me. 10cm should also be long enough.
Vini darko
Dorset England
I'm using a set of his rca's work fine and look nice. He dispatched quickly too.
Vini darko
Dorset England
£17 and look snake like and oily wich pleases me
MoveJoe
A set of very short right angle RCAs would also be nice. The ports seem to be on the left for both E30 and L30. So they should have a distance close to the thickness of one device to each other, maybe a bit more. So the length of the RCA cable would have to be around ~3,4cm.
CASE2112
St. Petersburg, FL - USA
Ordered!
drownie
Guesstimate ~ a week or two and I have no idea about plugs.
But from what I can tell all topping products on amazon are dispatched by SHENZHEN AUDIO and will be shipped from China.
That means you will have to pay custom fee I'm assuming.
gorman
When you refer to the combination of E30 and L30 as "SE", what do you mean? What does SE stand for?
Eetu
Helsinki
Single ended (RCA) as opposed to balanced like the Topping D90+A90 stack, for example.
3125b
Germany
9038q2m is more expensive than ak4493
Could you maybe comment on what sort of price range we are talking about, what these sort of chips approx. cost?
I could not guess that ... 5$ wholesale ...10$?
EDIT: And one further question, is the glossy front panel made from plastic or glass (what I assume is used on the E30)?
Gyroscopics
How good is the pre-amp stage on the L30? I don't see any specific writeup about it. I already have JDS Labs Atom, Massdrop THX 789, etc. for headphone amp. I'm only interested on the pre-amp stage of the L30. A90 seems overkill just for pre-amp use. Maybe this L30? I know, pre90 is coming, but will it cost the same as A90?
Edit: I found the pre-amp specs at Apos.
