Hi
Because of you people I tend to go to the cheapest option available... Has served me well, I will quickly add. I use this very cheap ...err.. inexpensive product and it works. Small caveat is that it has a slight delay, so Audyssey or other AVR room corrections, "see" the subwoofer a bit further than it's truly is .. it adds about 4 feet to the real distance. Else sounds OK to me in subwoofer applications. $59 on Amazon.
IFinity Wireless Link for Subwoofer and Surround speakers
You can only use one set (emitter, receiver) in a given room. If you need more channels, they have a 4-channel unit. I haven't tried that one.
P.S. The IFInity is 2-channel. I have one sub connected directly to the AVR and the other connected to the Unit. I plan to use it differently though;
AVR sub out to the miniDSP 2x4.
miniDSP Output One directly to sub 1
miniDSP Output 2 &3 to the Ifinity 2-channel Transmitter
Ifinity Receiver Output 1 to Subwoofer 2
Ifinity Receiver Output 2 to subwoofer 3 (Future)
I plan to carefully implement a Geddes-style 3 subwoofer system. Presently I am leaving it to Audyssey with the 2-subs, the results are OK .. Not superlative. IOW I have heard much better and know that I can have much better results. Strange thing is that there are seats positions in the room where bass is very good. At the main listening position not so much. I need to find my UMik and fire REW...
