Why can't a Sine Wave be used for testing high-power Class D amps?
bibio
Hello,
As the title suggested, I don't understand why a sine wave can't be used to test modern, high-power, class d amplifiers.
Some of the large PA amps I've recently looked at have dsp build-in which appear to clamp down any waveform that looks like a continuous sine wave.
Would someone be able to explain the reasoning behind this? Is it the Class D amp or the SMPS that is the issue?
Considering the waveforms of some modern music, does this not affect the audio quality? Some synth music is very sinewave based. How does the DSP differentiate?
So if you can't use a sine wave, how could I perform a frequency sweep of an amplifier? I have one particular amp that has built-in dsp and speaker presets, I'd like to see the crossover point and such.
Thanks in advance for your help.
fpitas
Northern Virginia, USA
Amir does use a sine wave sweep to test FR. And a series of sine waves to test IMD. I'm not sure I understand your question.
fpitas
Probably because they don’t want to deal with the associated warranty claims
Wait. Amir drives the amps all the way to clipping with sine waves.
fpitas
Perhaps OP meant square wave testing?
Steve81
Silver Spring, MD
As to how it works, use a real-time FFT to analyze the waveform, and set the threshold of user dumbassery you are willing to accept.
fpitas
I feel like another conversation is going on that I can't see.
fpitas
Look up what an FFT is, preferably with pics for better understanding. Then you’ll know how.
Huh? Now I'm really lost. A sine wave will just give a simple line.
fpitas
Or is this an elaborate troll?
fpitas
fpitas
You're very rude.
Roland68
Cologne, Germany
Hello,
Could you please post a link to the amp?
fpitas
Here's a typical test done by Amir:
Everett T
I've seen Gene at Audioholics post that certain high power Class D amps don't like sine wave testing, mentioning the Pascal modules but couldn't find where he explained why. He just noted his listening tests didn't jive with the measurements, whatever those conditions were.
fpitas
JSmith
Algol Perseus
... until the OP comes back.
JSmith
Steve81
Silver Spring, MD
I've seen Gene at Audioholics post that certain high power Class D amps don't like some wave testing, mentioning the Pascal modules but couldn't find where he explained why. He just noted his listening tests didn't jive with the measurements, whatever those conditions were.
It really just depends on how the limiting thresholds are set, which varies from manufacturer to manufacturer. They don’t want Gene killing an amp any more than an idiot who thinks he’s clever (the most dangerous type).
On my subs, I have access to all that, but I never dared mess with Funk’s settings.
