- Joined
- Dec 5, 2019
- Messages
- 807
- Likes
- 640
I use high gain when using Sundara and HD650, I have a pair of Ananda on the way, my understanding is that they are far easier to drive then the aforementioned headphones.
My question is, is it still best to drive the Ananda with High-Gain? at a lower volume level, or should I try and see if I can get the volume I need from Low-Gain? my gut instinct says that Low-Gain would be better since it has lower distortion but I am not real sure on that.
Thanks!
Thanks!
