tiagobdonoso
- Joined
- Mar 19, 2021
- Messages
- 16
- Likes
- 6
I tried to understand this, and looked for answers all over, but couldn't really. I'm lost at the beginning of the learning curve and can't find my way back.
I use DDRC24. I stream directly from Qobuz in my notebook, then to the DDRC, then to amp (a hypex nc252), and to jbl arena120 and svs 2000pro sub.
My question is: what bit rate should I set as standard, and why?
Qobus has three options: hires 24 bits, upt to 192khz/ hires 24 bits, up to 96khz/ cd quality, 16 bits/ 44.1khz.
With Dirac Live, which I use, 48khz is max. So:
Should I leave at max and let the minidsp do the downsampling?
Should I choose any of the 24bits, just to use minidsp capabilities in terms of bit rate?
Or should I choose cd quality and be done with it?
I guess there won't be a lot of difference, if any, but I would like to know objectively, which one is better?
Thank you guys for all your patience!
