What is the point of upsampling?
Julf
Amsterdam, The Netherlands
Do it through measurements. No need for snarky remarks and the paranoid attitude.
Here's looking at you, babe. :)
That digital transmission and decoding/conversion is perfect. Or even audibly prefect.
Who here has claimed that? What we are saying is that properly designed digital transmission and lossless encoding/decoding does reproduce the exact bits that went in - or fail badly, resulting in dropouts or no sound at all. The bits don't change in subtle ways, just like your spreadsheets or downloaded programs don't get small errors from being transmitted, so from that point of view bits are bits.
tuga
Oxford, England
The data doesn't change. But reconstruction is not perfect.
Julf
That's a different story. The bits are still bits. What goes in comes out - as ling as it is bits.
Julf
Did you play stairway to heaven on ^it^.
Or was that on vinyl?
The source was digital - software-synthesized sounds and music. It often took the whole night for the computer to produce 60 s of music. I am glad we have slightly more computing power these days.
earlevel
This question is best asked by professional DAC developers, because they are the ones who use upsampling for some purpose, to implement filters for example.
Since there are no DAC developers here, the answers will be varied (to say the least).
Isn't this a little like saying that only people who design car engines understand why car engines have certain design traits? Not even a seasoned mechanic truly understands car engines, because they don't actually design them, but just use existing components?
Most of us don't design car engines—or DACs—because there is no need to, there are competent ones already out there, and it's pretty costly and time consuming to design and build a new one.
I'm sure that a lot of people on this board understand DACs very well, and can answer questions from people who don't understand them quite so well. :)
I think your main point was likely more to the fact you'll get varying levels of knowledge, and in some cases perhaps people won't understand the details as well as they think they do. But that's true of any topic in a public forum, including how to cook a rib roast. I haven't read the thread, but I suspect that someone who started out with no idea of what sense it makes to raise the sample rate, post-sampling, probably has a little better idea. They are not people who are likely to design their own DACs, so they are probably comfortable with a little idea of the reasoning. That is...I doubt they need an explanation from someone who designs DACs. ;)
bhobba
To answer the original question, the point of upsampling is when you put, say, 48kz material into a DAC at 48kz, you get a cascade of reflected images at higher frequencies of the recorded material theoretically forever. Some don't worry about it, and you have what is called a NOS DAC that some like. But since the frequencies go on forever, it can cause problems with amps, etc. So what you do is upsample it. A straightforward process is duplicating the samples to get 96k, 196k, etc. It is called 2, 4,.... etc oversampling. Eight times, oversampling is common. Then, those cascaded copies of the signal occur at a much higher frequency that is easy to filter without affecting the audible band. DACs often do that for you. However, some believe a better quality filter (technically with many taps) affects the sound quality. Rob Watts is a proponent of that with his M-Scaler; there are plenty of reviews on the device, and Rob has videos on it and how he designs DACS. First, how he designs DACs with massive upsampling:
Then, on the M-Scaler:
I like the M-Scaler, but others, some even more experienced Audiophiles than me, don't.
I know a DAC designer who solved the issue elegantly. He uses a standard DAC chip and the best quality Sowter Audio Transformer he can buy as output. That is virtually flat to about 70KHz and rolls off rather steeply after that, preventing any high-frequency stuff from being output. I have compared his DAC to much more expensive DACs like the Direct Stream, and IMHO, it is better. It is not better than a Chord TT2, but that is MUCH more expensive and not better than the even more costly Grandinote DAC - but they are the only two better DACs I have found.
Of course, better here means to my ears sounds better - if it is better, it depends on what you mean by better.
Thanks
Bill
AnalogSteph
.de
Mind you, if you just need a lowpass of a decent order and nothing else, I can think of substantially less costly ways of implementing one... two Sowter transformers by themselves are about as much as an entire rather competent DAC (e.g. Topping E50). I'd rather be throwing a few passives and an opamp or two at the problem.
Philbo King
Perhaps I need to learn more about digital sampling itself, but I just can't fathom what upsampling is supposed to do? Like from 44.1 to 192 gets me what exactly in the end?
Upsampling is a good way to determine 'true peak' values of intersample overs.
Killingbeans
Bjerringbro, Denmark.
Others just acknowledge that it does nothing audible:
bhobba
Mind you, if you need a lowpass of a decent order and nothing else, I can think of substantially less costly ways of implementing one... two Sowter transformers by themselves are about as much as an entire relatively competent DAC (e.g. Topping E50). I'd rather throw a few passives and an opamp or two at the problem.
Yes. It's how he differentiates his DACs. He once used a diamond transistor (an IC that implements a 'ideal' transistor look alike, but the current can flow both directions between base and emitter) output stage that sounded good to my ears. But he now prefers the transformers - maybe just for marketing. His DACs are cheap enough, anyway. We all know a lot of this stuff is just marketing. The Direct Stream does it that way but upsamples to DSD. I guess his marketing ploy is we do essentially the same as the direct stream but at a much cheaper price. I don't know what is happening, and I have a direct stream, but his DACs sound better. I don't use it because I directly connect to my amps, and his DAC requires a pre-amp. Plus, the difference isn't much.
Thanks
Bill
bhobba
Oh, the claims and counterclaims.
All I can say is having organised blind listening tests, especially where expensive equipment and resulting egos are on the line, is a royal pain. I remember one where a DAC had a different earthing path - straight away, the 'losing' DAC makers said that invalidated it with some extra agro thrown in for good measure. Two good friends were at each other's throats for a while - they calmed down and are back to being good friends.
Now I don't bother organising them, I suggest people shut their eyes while a reliable friend switches the component in and out - after matching volumes, of course.
Thanks
Bill
Killingbeans
Probably just some impedance issue f¤¤king up the frequency response in a way you happen to enjoy.
Was going to say that's better than nothing, but honestly it probably isn't. High risk of getting a false sense of security.
I'd say there's no need to bother with even that. For most people this hobby is all about wonder and waffling. Trying to introduce reality into the mix is just deeply insulting.
AnalogSteph
.de
I really have to drag my Latitude E6330 over to be measured one of these days. I swear it benefits audibly from upsampling (or rather starts to sound normal... it's mostly there in double speed, quad speed is a tad better). Either there's something screwy going on with the drivers (which is quite possible, they're old Win8.1 ones on Win10), or the ultrasonic aliases are messing with the output stage or the digital filter is terrible or something. I have no reference for how an IDT 92HD93 should perform. My E6510 does not have that particular issue but also uses another chip (92HD81B) and is still on Win7.
