What are some ribbons microphones with big bang for the buck?
Thanks for everyone's input. Right now I'm leaning toward either a Royer R10 or the Samar AL95. I was looking at the Cascade X-15, and sort of like the Vin-Jets for a more vintage type sound going by specs. A Beyer SM130 is an interesting idea. Apparently almost completely flat 100 hz-8 khz, but a steep drop above and below. Maybe it is mostly a voice mic I don't know.
In any case some of the other suggestions I had not looked into so thanks. It gave me more ideas.
What will you be using the ribbon mic's on? Which source will you be recording?
Whatever I come across. Most of my recording is of small groups with acoustic instruments. Plus vocalists. Anything from someone's basement to a small bar, to medium sized church. So stringed instruments, some flutes, violins, and vocals.
Nice. I highly recommend DPA microphones for those applications. Enjoy your endeavors!
DPA makes excellent mikes. I don't think they make a figure 8 condenser though that is not a requirement. I have some SDCs, MDCs, and LDCs, just wanted to try some ribbons. DPAs are a little beyond the budget for me. I don't do this for a living so a hobby. My current favorite microphones are the WA84s clones of the Neumann KM84s. Don't know how accurate the cloning is, but they are very nice microphones.
Just a passing note that the SE Electronics VR1 is the flattest and most extended ribbon I've ever found. It's been a little while since I measured them, but IIRC mine were flat about to about 10kHz and gradually rolled off above that. If you wanted to, a touch of HF boost would get them flat to 20kHz.
Of course, that means they sound more like a condenser than a ribbon. They're super-compact, and have useful output levels. A useful device overall, but IMO they don't do the "big/warm/classic" ribbon thing that some people might be looking for.
The VR2 adds a phantom-powered internal preamp with lots of gain. Might be useful, but even connected to not-particularly-expensive digital mixing desks (QSC TM30, A&H SQ6), I've never run out of gain.
I don't use my VR1s much any more, having taken the step up towards Austrian Audio OC818s and some Schoeps. Probably overkill for a live stage, but they make life easy for me.
Chris
Chris
I have looked at those VR1 and VR2 Voo Doo ribbons. They just missed making my cut. I don't quite want the old, old ribbon sound, but just a touch of it. I do like the size. One thing that appeals to me about the AL95 is also the small size. And that it is a pistonic ribbon which should be a little more durable.
There was some discussion of ribbon mics in this thread, beginning on page 2.
Gosh, this is interesting, at $999:
WA-44 Studio Ribbon Microphone
