AlphaSorel
- Joined
- May 4, 2024
- Messages
- 7
- Likes
- 3
Hi, I'm looking to take the small TT setup in my office and expand it into a dual TT/streaming space for near field listening. I've been pouring over the reviews here and on other sites, and the more I read into things, the less clear my upgrade path becomes. I quite frankly don't know what I'm looking for in terms of technical/scientific/objective measurements, I only know that what I have isn't exactly cutting it.
My home office is a 12'x12'x8' room in a newer house. It has some cheap acoustic treatment for the occasional amateur hour VO work with a dynamic mic, but it's not a "hifi" space. My current equipment, listed below, works as long as I don't crank the volume up too much. Much beyond 70db or so it starts to get harsh and sibilant.
Current equipment:
-Audio Technica LP120XUSB w/ VM95ML cart
-Pro-Ject Phono Box S2 phono preamp
-Schiit Magni 3+ Amp/Headphone amp
-A pair of Samson Resolv RXA6 active studio monitors
This is kind of an amalgamation of random equipment. Nothing really goes together or was purchased with this specific setup in mind, except the phono pre and the TT were paired. You might also realize I have no real option for wireless music/streaming. Right now I'm unplugging the input on the Magni and plugging in a portable bluetooth adapter with a 3.5mm to RCA splitter so I can stream from my phone. Not ideal.
While the audio from this sounds *fine* at low volumes, it's nothing special. The studio monitors obviously weren't designed to be used as hifi speakers. While they provide a relatively flat response and do ok in the treble dept (maybe due to the ribbon tweeters?), I do feel they lack a bit in the soundstage, the bass isn't particularly tight, and the amp hiss is noticeable. There's also no remote control for...anything. Not even volume control. Though I guess that's not a deal breaker, it would be nice to have.
What I enjoy is detailed listening at lower volumes. I listen to a lot of different genres, but primarily I enjoy rock/metal, jazz, classical, and movie soundtracks. Being able to hear minute detail in a busy mix is something I strive for.
The one thing I don't want though is a heavy bass response. My home office is directly above a bedroom, while the current equipment does not pose a problem, adding a subwoofer or anything super bass heavy is a nonstarter. I generally listen to the existing setup at around 60-65db, which is quiet enough it does not disturb anyone downstairs.
I'd like to get this to a point where I can use the setup for both vinyl and high quality streaming audio. What needs replacing, what can stay, do I keep going with active speakers or invest in an amplifier and passive speakers instead? What kind of budget should I even be targeting? I would say budget itself is not a strict limitation, but I don't want to spend anything too crazy. I think $800-1000 is a nice starting point, but I could go as high as $2,000 if it made a significant difference in the listening experience.
A couple of options I've been considering:
-Upgrade the speakers to another active set, such as Klipsch The Fives/Sevens, or KEF LSX II LT's which offer a bluetooth connection built in. Probably around an $800-1200 upgrade
-Ditch the existing phono pre and amp, and buy an integrated amplifier of some sort, but it needs to be compact/half width. I've had several recommended to me in the past, including the NAD D3020, Mission 778X, Rega Brio, etc. I would then need passive speakers too, which I don't have any ideas for at the moment. I'm guessing $1000-1500 for this, minimum.
-Switch entirely to a headphone listening setup. I don't think this is necessarily a good idea? I wouldn't even know what to look for if I did want to go that route.
-Somehow find a way to fit a full size AVR with room correction like a used Denon X3500H. Again I'd need to buy some passive speakers for this and I have no idea what would be comparable/better to my current ones. Probably $1000 for the AVR + speakers.
Please help a noob that's hopelessly in over his head figure out what to do, or at least where to start? I don't even know where my speakers sit in terms of accuracy & response curve as they seem to have been overshadowed by Samson's other Resolv lineups and thus were not widely reviewed, so it's difficult to know if any given speaker is an "upgrade" or a "downgrade"
EDIT: I'm also seeing an option for a standalone room correction module through something like a MiniDSP. Are these worth it instead of pursuing a different amp entirely?
Current equipment:
