Wavelet is such a miracle
Starpointer
I have got the buds pro and at first I was a little bit disappointed as I was literally downgrade from a 7 units 1dd 4ba 2est iem to the buds pro. Then I try to toggle the samsung built-in eq to decrease the mid bass and lower mids. It sounds better but nothing groundbreaking.
Until I was recommended wavelet, I have toggled the GEQ for a bit.
Then miracle happens. The EQ turns out to sound like u12t in tonality according to my vague memory with crazy amount of details that I would never expect to hear them coming from a tws IEM! However I was still not satisfied.
I have bought the full version which have included the bass tuner.After setting up the the bass tuner.
It sounds deeper with more body. I am finally satisfied with the sound of my buds pro.
Then I also discovered autoeq.
I immediately grab my dusty wh1000xm3 and apply the autoeq with ANC on as ANC sounds the best for me. I then quickly put a smile on my face. That annoying thumpy muddy sound was totally gone and a more neutral sound creep in, which turned my disappointment to amazement! However, one issues I have with harman target is the lack of high treble
(+10khz). I have used the GEQ to adjust the high end of it.
It sounds so so great.
I have also got another surprise. I have got Anker soundcore motion boom. In fact the bass can sink down to 40hz, the sound pressure of the bass not ideal. I have applied the bass tuner on 56hz 5.0db makes the speaker sounds bigger thicker and more impactful.
I have applied a new eq in the anker app and also toggled the eq of wavelet.
After applying this 3 settings the soundstage was increased significantly and also effectively compensate the early treble roll-off due to SBC codec.
Except the audio miracle it has brought to my audio gears. It is also outstandingly convenient with the settings was saved via bluetooth devices which the settings will automatically applied according to the gears I have connected.
WAVELET IS A FREAKING LEGEND
I made it even better since you can now import Amir’s EQ profiles with my guide:
https://www.audiosciencereview.com/...ds/list-of-amirs-headphone-geq-filters.20043/
This. Not only can you import Amir’s PEQs, but Oratory, Crinacle and a few others PEQs are already built-in to autoeq (they’re not all good but worth checking). If you have phones with no decent measurements (like the B&O Beoplay H9 3rd gen with Bluetooth and NC on), you can tune by ear using Peace and a sine sweep, then import your custom PEQ using the method above. Took me about 20 iterations to get right, but finally those H9 3G’s sound as good as they should be!
Wavelet app is even better than you thought :)
Hi everyone. I use Usb Audio Player Pro with my Buds Pro, I've been fiddling with the EQ a bit, but really what I'm looking for is someone who can convert these 7 Band EQs for the Buds Pro into PEQ? I have the PEQ add-in working with my DACs and certain headphones, but can't seem to find a PEQ that tames the 8k a little and sorts out the bit of bloat in the 200k sort of area?
I really wish Wavelet would add crossfeed. That would be a game changer for me.
Nothing Android does it for streaming, and I can't understand why.
UAPP has crossfeed if you use Tidal or Qobuz
What are the Wavelet's filter parameters? Are these peak filters? What is the Q factor, if applicable?
The Wavelet app let you seemingly modify linear the Harman curve (or any other target curve) for personal maximum transparency.
As far as i know the only DSP app that let you do that works for me excellent mostly 63% correction does it for me. If recording needed i use more or less.
I'm not by far a parametric eq specialist but i wonder why Wavelet is probably the only DSP who let you linear adjust your measured target curve. If i'm correct due to basicly almost no phase or time alignment issues (regarding headphones) a frequency lineare adjustment it look the way to go like here under or are there other issues to consider??
I'm not by far a parametric eq specialist but i wonder why Wavelet is probably the only DSP who let you linear adjust your measured target curve. If i'm correct due to basicly almost no phase or time alignment issues (regarding headphones) a frequency lineare adjustment it looks like the way to go like here under or are there other issues to consider??
Whilst I don't know exactly how Wavelet works, a graphic EQ is simply a PEQ but (1) the frequencies are fixed, (2) there is no Q adjustment, and (3) only the gains are adjustable. Since most PEQ's are minimum-phase and therefore rotate phase with frequency, I would be highly sceptical if Wavelet is any different.
I'm m not much of a headphone listener but when i do i find my self regular use this Wavelet feature depending of the recording an for whatever reason i get (probably subjectively) constant the desired balanced transparant sound. It varies between 100 an 50 % adjustment something i can't find in other solutions. Just curious if other ASR members use this feature an what are there experiences
