- Joined
- Feb 28, 2024
- Messages
- 124
- Likes
- 223
- Thread Starter
- #21
Hello, thank you for your attention!This looks like everything I would need to finally ditch my 30 yr. old integrated and move to 21st century technology. I do have a few questions.
My current amplifier is only 60w/@8R, 100w @4R and I need more power for the speakers I use 83db/1w/4R. That rated output is at less than .005% thd. from 20-20khz. Yes, 20khz, for some reason they cared about it in the old days.
The thing is this amp has a linear supply and can produce peak outputs (100ms) of 170w@4R and 280w@2R. It will deliver somewhat less power at 1 ohm than 2 even though the transformers are hardly what I would consider beefy.
The question is, can your rated 300w/4R@10% thd. amplifier play my speakers louder with less distortion vs the amp I have or should I just stick to buying a higher powered class ab amp with a linear supply?
Also, what is the efficiency of your amplifier when producing a 1w steady state output?
This power amplifier is class D, with higher efficiency than class AB amplifier.
As for the data, we cannot provide now since the final version hasn't been determined yet. And I will post it when the data is measured.
Stay tuned.
