The first minute or two sets up a couple of red herring arguments that led me to believe that he does not really understand REQ or he chooses to to mislead the viewer for his own reasons.
I won't bog down the thread with a lengthy response. Wrt your last point, actually Dirac (and the other software I am referring to), does indeed correlate the phase response of the left and right speaker: "the latest Dirac Live 2.x algorithm might even slightly compromise on FR response of one of the speakers in favor of the best possible phase coherence between them that is important for imaging."
What hasn't been addressed and my point with a few commercial software being used is "excess phase" correction at low frequencies. I have tried MMM technique several times and it does not deal with excess phase at low frequencies. I have also tried MMM with rePhase for excess phase correction and is not the same, but closer, to the commercial software. What I am discussing isn't "magic." In this article, one can see in the time domain a maximum phase peak caused by low frequency room reflections, that are corrected in the time domain. It certainly is audible to my ears.
@QMuse Yup, that is similar to what I get too using the same technique...
Curiously, remove the FDW setting, use REW's default 500 ms window and 1/12 oct smoothing and set the vertical scale (+- 180 degrees) and horizontal scale (10 Hz to 200 Hz) like in the screen shot below and lets see the phase response below 200 Hz. This is what mine looks like with large double 15" woofers in ported cab per side plus dual sealed 18" subs crossed at 46 Hz in a room that sucks, plus an asymmetric setup:
@QMuse As expected. And while room construction has some effect, at these wavelengths it is simply the dimensions of the room that define room modes. I wouldn't call commercial room correction software toys... but I forgive you
Let's have some fun and send me your uncorrected measurements and take this OT offline. I can't get to it right away, but will over time.
Interesting. You measure the frequency corrected output with sweeps, at the LP or near field, and does it matter.When doing manual correction I'm using MMM RTA with pink noise as a basis for frequency correction. Once I fix that I take one or more sweeps (with vector averaging) to gather phase response which I then correct with rePhase.
I'm using Mathaudio room eq with a NAD C370 for FREE with foobar2000 did compare it to a Lyngdorf system cost a round 4000,- did exactly the same correction IMO. Suggest download it for free buy for less than 100,- a measuring mic & mic stand put it on a Mac OS or Windows OS an compare bypass & roomcorrection setup. Than decide to Stay with the used setup or use dirac Lyngdorf minidsp or other solutions. Despite a small investment in a measuring mic & mic stand there is 0 investment risk in trying room correction this way.Room correction is definitely always worth it but it can be done for much less than $1100.
To dumb it down for a moment for the more basic among us, how worthy (or not) is the room correction embedded in AVRs from Pioneer, Denon, Yamaha? How much more 'correct' correction can be had with external units and/or taking measurements from multiple positions?
Here's my poinon on this.. When you listen to uncorrected response even with the speakers with superior spinorama measuremetns chances are you are listening to +/-15dB amplitude swings in the 20-300Hz range, make it +/-10dB if you are lucky - and that results in pretty much horrible sound.
Expect half of that trouble within 300-900Hz range.
Premium room EQ system, assuming well executed, can reduce that to +/-3db, but it is afe to assume every one of them will achieve +/-6dB, which still a HUGE improvement over the uncorrected response.
You should be aware tha tevery room Eq system is sensitive to "garbage in-garbage out" effect so following the instructions when taking measurements is essential, but the conclusion is that even the basic room EQ will significantly improve SQ of your system.
It is hard to estimate the improvement of AVR built-in room EQ systems vs the stand-alones alternatives - probably the latter are stasticaly better, but the important message here is that any room EQ system is BY FAR better than uncorrected response you're gettng with your speakers, and that is true no matter how superior their anechoic response looks.
I have to agree. His comments about altering the intent of the artist/engineer are just completely off base.
