USB Audio to Toslink (S/PDIF)
FireKahuna
I have an Audeze Mobius headphone which outputs USB Audio Class 2, I'm wondering if there is a way to take USB audio and convert it into S/PDIF to use with my LG C1 TV, Digital to Digital basically. Is this even a thing? Cant seem to find something on this lines. Even if its just 2 channel.
The headphone also draws power from USB, so idk if something exists with its own power supply
Topping makes an inexpensive DAC that has a USB input and S/PDIF output in addition to the converted output. Model # escapes me at the moment.
so the headphone is acting as a bluetooth receiver and outputting through USB or does it have wifi connectivity? (i am curious, wasnt aware there are headphones that output audio)
There's a ton of these out there. Here's a typical one. I have an older version and it works perfectly.
All gaming headphones equipped with microphones do this. The Mobius is marketed as a gaming headphone. The microphone is removable though, so can be used without.
Reactions: MCH
OK, so the headphones are a regular USB audio device with playback and capture capability. The headphones must be connected to some USB host (basically a computer) which will have SPDIF output (as another sound device). Basically any USB soundcard with SPDIF output will do, as an example.
The computer must capture samples from the USB headphones and play them to SPDIF soundcard. If both soundcards use same clock (e.g. both are USB devices in adaptive mode, connected to the same USB controller via USB hub, internal or external), simple capture -> play will do. If the soundcards have independent clocks, the stream must be adaptively resampled to align the two clock domains.
All requirements can be served e.g. by an RPi running alsaloop or camilladsp in linux.
