Tube Rolling: Does it Make a Difference?
Keith_W
Melbourne, Australia
I did not read through the 29 page thread. But if someone hasn't mentioned it yet - the tolerances for tube manufacturing are not the same as any other electronic component. This is because they are by nature more difficult to manufacture, and it is more expensive to discard the tube if it is out of tolerance. So tube amps are designed to compensate for a the inconsistent performance of tubes.
A friend of mine who repairs valve amps and has a tube tester once told me that he has never found a pair of so-called "matched tubes" to be exactly matched. Tubes that come out of one manufacturer might have different tolerances to another manufacturer, and they might have different interpretations of the standard. All that matters is electrical performance of the tube and how closely it matches the standard which the amplifier was designed to meet.
His conclusion: hearing differences with tube rolling is real. Even changing tubes from the same manufacturer can result in measurable and potentially audible differences. However, spending money to buy expensive tubes is not worth it, unless the extra money buys you tighter tolerances and better build quality and not better mystique and better marketing.
SIY
Alfred, NY
Tolerances for tubes are actually tighter. For example, FET transconductance and Idss can have. 5:1 spread.
mhardy6647
The thing about commercial designs is the cheapest components are selected to maximize profit. Maybe consider replacing electrolytic caps in crossovers with cost effective polypropylene caps... Just don't get carried away with the expensive parts that only provide "buzzword bragging" rights.
No argument, there -- and I do agree vis-a-vis NP electrolytics, FWIW. :)
My point was directed at the lunatic fringe. ;)
fpitas
Northern Virginia, USA
But they usually have the most enthusiasm.
MattHooper
This says a bit more than you likely intended. :cool:
I assure you nothing unpredictable escaped that post.
I've been around a long time and I'm quite aware of the context of such a post on this forum, including that it will be seen as red meat to some.
In particular, your response was predictable down to the granularity of a precision micrometer. :)
And that's fine of course. I understand, and all the appropriate caveats are there as usual. For anyone who misses the caveats and becomes triggered by my subjective flourishes: see my tag line. :cool:
mhardy6647
that they do...
fpitas
And keep in mind Beranek's Law. Which admittedly has to be stretched somewhat to include "re-designed" speakers:
"It has been remarked that if one selects his own components, builds his own enclosure, and is convinced that he has made a wise choice of design, then his own loudspeaker sounds better to him than does anyone else's loudspeaker. In this case, the frequency response of the loudspeaker seems to play only a minor part in forming a person's opinion."
—L. L. Beranek, Acoustics (McGraw-Hill, New York, 1954), p.208.
MattHooper
I think it's also worth remembering how limited personal experience is ingrained in our viewpoints, whether someone is a pure "subjectivist" or if they are seeking to be a very empirically rigorous engineer.
We live in a very big, complex world, using small imperfect brains and our abilities to rigorously test all our beliefs is going to be limited. So even engineers are left with what seem to be received best practices or information, some of which may suffer *some* level of dispute (as one finds in science) and then that engineer's personal experience working on a problem or idea is going to ultimately heavily sway their view. So in science you'll find various scientists defending their pet views, in engineering the same. Through personal experience the technically inclined will arrive at their preferred solution, which may not be shared by another who went down an different avenue. (Hence, in audio, different speaker designs, amp designs, etc).
That's not for a moment to suggest empirical reality and hard won knowledge is just a free for all or purely subjective. Nor that some positions are more justifiable than others. Very far from it. Just an observation that it's understandable why disputes remain even among engineers and scientists, and various technically knowledgeable people.
fpitas
I agree with all that. But like Dr. Hardy complained about, some people are more than willing to tear into things they have no knowledge of. But on the other hand, my opinion is they paid for it, so they can screw it up all they want. Dr. Hardy on the other hand, perhaps believes some lèse-majesté goes on.
mhardy6647
I agree with all that. But like Mr. Hardy complained about, some people are more than willing to tear into things they have no knowledge of. But on the other hand, my opinion is they paid for it, so they can screw it up all they want. Mr. Hardy on the other hand, perhaps believes some lèse-majesté goes on.
ahem.
Dr. Hardy.
Just sayin'.
:cool::facepalm:
On topic: actually, perhaps the best thing about tyros re-engineering electronics may be... natural selection. :eek:
electronic-sparks-scatter-quickly-and-sharply-from-a-short-circuit-on-technological-equipment.jpg
fpitas
ahem.
Dr. Hardy.
Just sayin'.
:cool::facepalm:
He meant to do that!
And I doctored my last post. So to speak.
MattHooper
I'll be completely honest (even though the following goes without saying at a place like ASR): The simple and non-optimal (objectively speaking) design of my chosen power amplifier (single ended 2A3, zero added NFB) is the root cause of its sensitivity to the electrical properties of the active components (tubes) used in it -- maybe some of the passives, as well. So -- instead of little knobs to turn to adjust the tone or contour, one may swap tubes to accomplish the same thing! It's much more expensive, and less predictable! But it's fun. In fact -- it's fun to even know one may do it if one wishes to, whether one actually does "roll tubes" or not! :)
Yeah, I definitely admit to having a foot in old school audiophiledom in that regard. I get why people like to "tweak." It's involving, helps you feel like you've guided sound exactly to where you want it, put something of a personal stamp in there. A bit different from just wanting a system to do it's job reliably, accurately as it's supposed to do it, where you *don't* want your personal touch messing anything up.
Some audiophiles aren't technically proficient so keep this in the 'audiophile tweak' realm (including the voodoo stuff), while others more technically proficient and inclined take the desire to have personal input right to the DIY level. Which is cool.
Brubaker
Matt, hai appena avuto un'esperienza di prima mano con il tuo orecchio/cervello che ti ha ingannato facendoti credere che ci fosse un enorme cambiamento nelle prestazioni. Giureresti su una pila di Bibbie che il cambiamento è stato reale, molto grande e chiunque poteva sentirlo. Ma, una volta testato, non sarebbe evidente. Ecco quanto è potente e sorprendente l'effetto. Questo è il motivo per cui i soggettivisti hanno attacchi riguardo alle misurazioni. Per loro e per la tua esperienza è reale. Il tuo cervello sta dicendo che questo è reale ed enorme. Ecco perché è così complicato. Anche Amir NON è immune all'effetto. Colpisce tutti. Non c'è modo di pensarlo.
È sorprendente, vero? Quando riesci davvero a comprendere l'idea, ti apre gli occhi sminuire così tanta parte del mondo dell'audio che commercializza stronzate mumbo jumbo. Finché non succede a te è difficile crederci. Cavolo, stavo sintonizzando un equalizzatore per il mio sub qualche tempo fa e ho apportato un sacco di grandi modifiche per sintonizzarlo perfettamente. Poi, quando sono "arrivato" ed ero pronto per concludere la giornata, ho controllato il sub e ho scoperto che ERA SPENTO . L'avevo spento qualche ora prima e mi ero dimenticato di riaccenderlo. Questo è stato l'ennesimo schiaffo in faccia per quanto sia forte il cervello nell'ingannarci. È davvero sorprendente se ci pensi. Grazie per l'ottimo post!
I love it.... funny... it makes me laugh a lot....
musicforcities
Op amp rolling is the new tube rolling…
Tubes have such a relatively wide margin of variation that it seems not unreasonable that changing them could impart marginal effects. Especially in preamp stages. Especially for old tubes, which age unpredictably. And issues of matching especially if there is a tube for each channel, which can create effects in the stereo field. Heck, just changing the tubes can dislodge oxidation of pins sockets to create marginal improvements in extreme cases. Many socket connectors are not exactly “airtight” and prone to collecting dirt/dust/airborn stuff.
But unless one had two identical preamps set up in the same system do a proper blind test, the time it takes to swap tubes alone makes any perceived differences very unreliable.
egellings
I never understand why it's called "rolling tubes" as opposed to "changing tubes". It seems to imply some inherent skill involved in the process.
Maybe 'rolling' is used due to a tube's propensity for rolling off a non-level table and hitting the hopefully carpeted floor.
Angsty
North Carolina, U.S.
I'd attribute it to the phrase "rolling your own", which relates to smoking weed.
Angsty
But the sentence that follows could be applied to audiophilia, writ large: "In this case, the frequency response of the loudspeaker [or other device] seems to play only a minor part in forming a person's opinion."
Brian Hall
Southeast Oklahoma
Instead of messing around with tubes, wouldn't it be simpler if someone just made a preamp that contains the circuit board from a guitar distortion pedal with a dial on the front of the preamp to add the desired amount of distortion / audio corruption to the audio signal?
Instead of accurately labeling the dial as distortion, it could be labeled "Tube Warmth". Same effect.
Maybe Fosi should look into doing that.
In case it isn't obvious, I do not understand why anyone would want to corrupt their audio playback signal with tubes. It seems very counterproductive.
DMill
As someone with an office system based on an integrated tube amp. Tube rolling is not about hi-fi as much as collecting something valuable and old that has been stashed away in some basement for 70 years and never used. I do “think” I hear a difference when changing out tubes, but it is so low-fi and becomes comparable to how spicy do you like your curry, why bother even testing? I know this site is about absolute fidelity, and tube amps measure poorly and yesterday’s news. But there is something still charming about glowing bulbs that produce better sound than you might think. Very much good enough to get lost in the music.
Doodski
The last tube integrated amp that I had was a Sherwood. Pretty as can be when all shiny and dusted. I paired it with very bright speakers and it all sounded fine and dandy.
