Transmission-line speakers
Everett T
View attachment 212261Interesting thread! I am slowly working towards rehousing my drivers, so after reading the thread, I decided to model a 1/1 transmission line (very roughly, as I am still waiting on a couple resistors to measure my current drivers). I wanted to keep it as simple as possible so the speaker is a 17.4 meter tapered rectangular tube sliced into equal length sections with the paired ends (from inverting the even sections) capped at heights equal to the width of the section. Woofer is 12”.
It comes in at 2.777 meters tall and 1.068 meters deep. If it was made from 1.5mm thick aluminum, the housing alone weighs 59 kilos. Need a room with tall ceilings!
CST and complexity wise, and think I’ll stick with a sealed or ported box. But it was fun to do.
I've seen a couple of full stop transmission lines built into the foundation of houses, that's dedication, lol. Please post your driver and final numbers, thanks.
DanielT
Sweden - Слава Україні
Example
No. I would not call that a Transmission Line design.
What you call it is not so important, the graphs show behavior of a high-q ported design where the port resonance in the low mid is a classic example of faults that can and should be fixed.
Tip:
It was a coincidence. Speaking of them::)
RonSanderson
I wouldn't wake up this old thread, except I think there is still more that has been missed.
Irving M. (Bud) Fried was the original importer of IMF speakers (note his initials), and later produced his own under the Fried name. He was a firm believer in transmission lines - I have two models, the IMF Studio III from 1972 and the Fried Studio V from about 1995. They are still in daily use.
I have most of his marketing newsletters from 1961 to around 2000, where he discusses how transmission lines work and why he used them. The attachment "The Virtuous Transmission Line" is most relevant to this thread.
I am attaching the brochure for his System H, which may be one of the first, if not the first, subwoofer / satellite system. For those in a hurry, sections IV and VII are most relevant here. This system must be at least 50 years old by now. (Edit: introduced in 1975.)
A few decades later his enthusiasm for TL's had not wavered.
One assertion is that the back wave from the speaker is attenuated and delayed by placing resistive materials in the line. The goal is to match it to the direct output from the speaker, but coming out from the bottom front vent. He asserts that this creates a coupling between the front and rear speaker energy that produces a planar wave front for the bass, which is much larger than the wavefront produced by the speaker cone alone. He also asserts that this reduces room interaction compared to that produced by a single point source.
"Transmission lines: By their nature, as described in a 1970 article written in "Hi Fi News" by an English associate and myself, lines appear in rooms as planar sources, with much less energy going randomly to the walls (as in "spherical source" loudspeakers). Thus, there is much less room interaction with lines, and purer response no matter where situated in the room."
I also attach some of the marketing materials and newsletters about the Studio V. In the printed blurb at the beginning of this file he discusses the difference between using a transmission line in the bass and what he terms a "line tunnel" for the midrange. There is other stuff in the PDF file that is not relevant to this thread. Sorry, but I had it all bound into a single unit. There is, however, a picture of the transmission line in a cutaway drawing.
Finally, I attach two pages discussing the design of the Studio V in which he further discusses TLs. "The Virtuous Transmission Line" is a blurry copy of an article from "Hi-Fi Heretic", a publication I never heard of!
I hope this sheds some light on the views of an insider and one of the transmission line's biggest proponents.
  • Fried Model H info.pdf
  • Fried Studio V brochures.pdf
  • Studio V Preliminary p.1.pdf
  • Studio V Preliminary p.2.pdf
  • The Virtuous Transmission Line.pdf
pseudoid
...The Distortion and Frequency Response performance of the IMF TLS 80 are detailed in the measurements shown below:...
OT: Those Brüel & Kjær print-outs (mid '70s) you posted bring back much sweet memories, as a young EE.
We were working on a contract for the original digitization of analog ... at the tip-of-the-technology - secure (encrypted) voice communications @2.4kbps - of the era.
The [ummm...] contracting agency had drop-shipped us set of two 8-foot rack fulls of Brüel & Kjær test equipment and a pallet of ancillary hardware.
We were told to perform some exotic "audio intelligibility testing" on the terminals (secure phones) as a part of our contract.
No one in our engineering department had realized that we may had gotten ourselves in deep doodoo << because we did not even know (or had ever used) such a compilation of buttons on test equipment.
It took few of us grunt EEs nearly a month, inside some hi-security lab's anechoic chamber (30'x30'), to get proficient with the hardware and audio measurements.
Fortunately, we managed to impress [ummm....] our customer that [ummm...] all things considered... [deplorable] 2.4kbps voice-digitization was 'intelligible' ... at least, when it came to pangrams that were drilled into our brains continuously for 3 straight months.
The supporting documentational reams of Brüel & Kjær plots/graphs/print-outs for [ummm...] our customer measured in 'pounds' and not in 'pages'.
In hindsight: Us punk-EEs were thinking we were invincible for conquering what is now done at the press of a button on some "cheap" AP...:cool:
Thanks for the memories.
renkitch
I've just built some TLs - parallel duct, 1/4 wavelength, rear-top exhaust. 1.16 x 0.3 x 0.3 m. It predicably and repeatably, resonates in the lower register, and there is a significant (-12 dB) attenuation at around 89 to 90 Hz. The tweeter, which is sealed, also has significant resonances, whereas the spec sheet shows a flat response. However, trying some temporary DSP EQ, it was a shock to discover that I could get the response flattened to a reasonable level, and the sound improvement was significant. The trouble with resonating type speakers is that the bass doesn't 'belong' to the music - maybe because the bass waveform takes time 'to resonate'? With my TLs, the bass is tight - and it is deep. I'm now making a hardware version of the EQ (it needs high-Q responses).
617
Somerville, MA
The impurities induced by the summation of out of phase bass from the back of the cone being combined with the front by means of a port or transmission line pale in comparison to the chaos created by our rooms.
I am a big fan of traditional loudspeaker design, but I think our collective understanding of bass reproduction has moved on from worrying about bass alignments too much - Geddes for example in his speakers said he didn't worry about the 'thiele small stuff' and put his midwoofers (12"+ pro sound woofers) in sealed enclosures of arbitrary size, and the subwoofers he used to sell were bandpass solely to get the desired output.
Head_Unit
This seems to be a conflation with like a line array of speakers as used in many PA systems. I like transmission lines...still look on eBay etc for a set of Celestion 300s...but the source is still a woofer and a "port"* which does not make it into a line source at all.
I recall George Augspurger wrote a program for calculation TL enclosures; I think I still have it somewhere. What I don't recall seeing is any TL systems actually measured, let alone compared to sealed and ported. ?!?!?!?
*what DO we call the open end of a transmission line?
Head_Unit
[Effective ATL™ Length: 1.72m / 5.6ft] The wavelength of 50Hz is 7m, which is four times longer than the transmission line used in that speaker. If a manufacturer that is a big advocate of transmission line flunks their own theory that much, and openly, I have no respect for them nor I think should anyone else.
Doesn't that make it a 1/4 wave TL? Which I'm not recalling how effective that really is.
And now, it is time to mention the Bose Acoustic Wave Cannon! Perfect sound forever, and we've made your amplifier twice as powerful! (ha ha when I once met Richard Small at Harman in Indiana he was a bit embarrassed about that latter statement. Although actually when the Power Cube came along later, perhaps he shouldn't have been!)
renkitch
A really good question Head_Unit. I called it the exhaust once. According to AI - In church organ pipes, it's called the "Mouth", or technically, the "Antinode" for a 1/4 wave etc., if it's the open end of the pipe, opposite the sound source.
Matt_Holland
I was given a pair of PMC DB1+ small bookshelf speakers. I’m seriously considering to block up the rear port.
renkitch
I’ve seen “terminus” used as a more common name for the open end of the transmission line.
*shrugs
Yes, electrical data transmission lines have 'Terminators' to stop/reduce reflections (i.e. to stop the wave bouncing back) - which has the same function as an open duct - so 'terminus' seems related...
*Shrugs as well.
Head_Unit
Rooms are awful.
Hmmm, maybe instead of building a custom listening room, I should be focused on building a pavilion in a large farmer's field!
We went to the wonderful Upscale Audio...where speakers are more in the middle of very large, treated rooms. Yes stuff sounds more wonderful. At home...not quite so. Then again that should not deter us from improvement, like the folks who say audio is wasted in a car or a boat or whatever. Er, the sound will never be as pristine, but that doesn't mean you can't improve it to sound really enjoyable.
