Just registered here only to answer this question lol :-DAnyone can recommend a pouch that can fit the G5, pair of IEMs, a USB cable and nothing more?
Thanks for the info. It is a bit confusing that digital-in and analog-in measurements are on the same graphic. The G5 digital-in should probably be listed with other dac-amp-combos while the analog-in listed with other amps like L30.@thanrl on the G5, it was most likely tested with digital in.
Ditto for DAC+Amp combos in general as the majority of those don't have analog inputs in the first place. Only the FiiO K5/7/9 afaik.
Hi dears, back to my previous post to which you guys basically said there were no solutions... I dug a bit more and found these apps.So I ended up buying the Topping G5 and I’ve found its bluetooth quality to be not that bad at all when paired with an iPhone 14 Pro. It’s just so so convenient. So the only problem now is that I’m listening to the original frequency tuning of the Sennheiser HD800, which is too bright and light for me. Is there an iOS app that fixes this problem like Sonarworks does on my macbook pro? Or do I need just a general parametric eq? (I use Tidal on my iPhone to listen to music)
For me it was 40min in high gain- If the red light is on how long can you listen until it is empty? 1h?
A rolloff like that is not remotely high fidelity. -14dB at 20kHz is a bad joke. The pioneers of digital would be rolling in their graves.
But, kill that much HF and your THD will look fabulous....
@amirm How can you give a product with such a brutally bad (and clearly faulty) HF response such high marks? It makes no sense. And that is at 44.1kHz. This is what they claim:
What's going on? It's either faulty, your tests are botched, or they are lying with their claims.
https://decibelpro.app/blog/sounds-...age of 25,developing age-related hearing loss. After the age of 25, this normal range of up to 20,000 Hz drops. Then, we are able to hear sounds with frequencies between 20 and 14,400 Hz. This happens because of naturally developing age-related hearing loss. So I am enjoying my Topping G5 and you worry about frequencies you cannot even hear. And this is not over 50 like Amir and I. This is 25.A rolloff like that is not remotely high fidelity. -14dB at 20kHz is a bad joke. The pioneers of digital would be rolling in their graves.
Possibly a bug. If I switch while the relay is "working" from USB to aux, and back to USB, everything is ok again.As soon as the batteries are not quite full,
and I turn off the device, a relay flips.
Is anyone aware of this problem?
My G5 is 2 days old...
https://decibelpro.app/blog/sounds-only-kids-can-hear/#:~:text=After the age of 25,developing age-related hearing loss. After the age of 25, this normal range of up to 20,000 Hz drops. Then, we are able to hear sounds with frequencies between 20 and 14,400 Hz. This happens because of naturally developing age-related hearing loss. So I am enjoying my Topping G5 and you worry about frequencies you cannot even hear. And this is not over 50 like Amir and I. This is 25.
