Topping E50 Review (Balanced DAC)
Overseas
I looked to manufacturer site, in support for updates, for E50 they say 'tool for checking the no. of firmware', to download.
wanghao
japan
It is inconvenient that I cannot switch between DAC mode and preamp mode with the remote control.
Are DAC mode and preamp mode 0db the same?
Is it necessary to switch to DAC mode?
Stickler1
Over By Dere
This is a review and detailed measurements of the new Topping E50 balanced USB DAC. It was sent to me by the company and costs US $269. I just reviewed its companion headphone amplifier, the Topping L50.
The E50 takes my favorite orange LED display and makes it even nicer!
It is a gorgeous bright orange display. A single button turns the unit on and cycles through the inputs. You also get a remote control:
As you see, power is provided through a 5 volt barrel connector. Topping provides a USB to barrel cable adapter so you can use any USB power supply.
As with more recent Topping products, it uses TRS output for balanced output instead of XLR which takes up a lot more space.
Topping E50 Measurements
As usual we start without dashboard. Let's test the balanced output with USB input:
Another exemplary performance from Topping, landing it almost at top of all DACs ever tested:
RCA output is nearly as good:
Noise performance is excellent as well:
Linearity is as perfect as you can get:
IMD performance is excellent:
I see a hint of ESS dac chip IMD hump. I wonder if that is what powers it.
Multitone performance is superb with almost no frequency dependency:
Jitter over USB is perfect:
It degrades just a hair over Toslink/Coax:
There are three filers available:
They impact our THD+N vs frequency thusly:
What can I say but another star performance from Topping. Company is so focused on squeezing every bit of noise and distortion out of these products while providing them to us at bargain prices. And in this case, great looks as well. I wish I could complain about something but nothing comes to mind.
Now $299 at Apps. Cheaper than their refurb ones.
theoblue80
I got one E50 from Amazon at 199E.
I currently own a D90SE / A90D stack and since both E50 and D90SE have balanced outputs, excellent measurements and both support MQA, I am curious to see if E50 + A90D combo has any audible difference (at least in the USB input that I exclusively use) in comparison to the much more.expensive D90SE + A90D combo.
Scientifically thinking I expect no difference if TRS to XLR balanced cables do not differ from XLR to XLR cables :)
Leva
Guys, One more time. Yesterday I tried E50 with optical input from my 2 years old LG tv and it has dropouts about every second - impossible to listen. But Emotiva PT-100 dac working normally with the same optical cable and tv. I read thread about the same problems with E70 and found that there was firmware fix in version 1.04 with some DPLL settings here https://audiosciencereview.com/foru...s-defective-skipping-issue.39507/post-1413408
So what about E50? Will it be fixed for E50 also or I should buy another dac to be compatible with TV? Thanks
staticV3
Hi @Leva !
Unfortunately, here at ASR we do not develop firmware updates for Topping DACs.
Whether the E50 will receive an update that unlocks configurable DPLL, you'd have to ask Topping themselves here: https://www.tpdz.net/contact
My guess is no.
However, you can potentially bypass the issue with an HDMI Audio extractor, by going TV->HDMI eARC out->Extractor->Toslink->E50.
Amir has reviewed a few of these Extractors: Link1 Link2 Link3
They're essentially bit-perfect for HDMI In->Toslink/Coax/Spdif Out.
Overseas
I bought E50, tested it with my LG TV, negatively but I kept it for my main stereo system, where E50 'fixed' some aspects of my sound comparing to former E30 (that works with LG).
Thanks God for my subjective non-golden ears and I do not believe John Yang will object too fiercely against my subjective take, as long as it sells his products
theoblue80
By the way, a bit more general question, but if you use a DAC like e50 with HP Amp, does it make any difference if between them one uses balanced or single-ended connection, assuming that HP is connected to the balanced output of the Amp?
Does balanced connection between DAC and Amp provide more power to the Headphone or maybe less noise in the chain?
Reactions: GPJ
theoblue80
What kind of headphones and amp are you using? RCA to RCA is going to be just fine 99% of the time. There is no noise penalty using the E50 with either TRS balanced out or RCA.
TRS or XLR balanced ouput is usually around 4V. RCA is usually 2V. The extra voltage from the DAC can help drive inefficient headphones better sometimes.
Thanks a lot! This answers my question. Then no noise penalty, but the difference in output voltage does impact the power that can be delivered to the HPs (if needed)
staticV3
Ok good to know! At the moment I have a Topping A90D
On the A90D, Bal out provides more power than SE out regardless of what input you use:
