raif71
- Joined
- Sep 7, 2019
- Messages
- 2,354
- Likes
- 2,569
No A50s/D50s stack ?
The 3.5mm output of the A50s is wrong.
Just got my D90SE. Running it in DAC mode to SMSL DA-9 via XLR.
I hope you aren't hoping for flowery words, but I can say that my system sounds exceptionally clear and noise-free. In terms of usability, I just plugged it into my iMac and it works. The interface is easy, and it was a breeze to set up. I was using a Hidisz S9 previously and if I was forced to identify a difference, I'd say my bass is stronger now--like someone upped the gain on my subwoofer. I am thinking maybe there was an impedance mismatch in my prior set up, but that's an issue for another post.
At any rate, every good sounding recording I've played so far sounds wonderful. And the crappy ones sound crappy. I am getting the truth, and that's the goal of this system.
Is your D90SE running in DAC or Preamp mode?I got mine delivered today, however I’m not 100% sold on it right now. I’ve left it running in to see how I feel later
Set it up as a DAC. XLR into my ampIs your D90SE running in DAC or Preamp mode?
I really like to see how does it perform in Preamp mode?
I have both my Gustard X16 and the D90SE side by side and the X16 has a more open, spatial presentation. Also the bass on the d90se isn’t as tight. So I’m going back and forth with music that i know and I’m leaning towards the X16. I appreciate everyone hearing is different.ea666, please let me know what you're hearing that's displeasing you. Will be interested to see if I can hear it in my set up.
I wonder about the voltage output of d90se as compared to x16, when being fed same signals.I have both my Gustard X16 and the D90SE side by side and the X16 has a more open, spatial presentation. Also the bass on the d90se isn’t as tight. So I’m going back and forth with music that i know and I’m leaning towards the X16. I appreciate everyone hearing is different.
Single-ended output:I wonder about the voltage output of d90se as compared to x16, when being fed same signals.
I know that E30 is about 0.5db louder than my X16, when both being fed same signals. Thus, for fair comparison, I needed to turn down E30 by 0.5db.
@ea666 , there you go. You need to match voltages to do proper comparison. The D90se is not as loud as x16, when being fed same signals.Single-ended output:
Topping D90SE - 2.090 Vrms
Gustard X16 - 2.104 Vrms
Topping E30 - 2.145 Vrms
For the best comparison, use a multimeter with a 1 KHz tone and calibrate the output voltages to be the same.
I’m thinking of getting the X26 Pro…. Will see when I have some spare coins laying aroundI have owned the Topping D90 for over a year, and while a very good DAC... I just bought a Gustard X26 Pro (twice the price of a D90) and I also had it alongside my D90 (to A/B test it from the same source) and it was a much better sounding DAC.... DAC differences are pretty small, but myself and a couple audiophile friends had no problems discerning that the X26 Pro was a much better sounding DAC. The D90 will now go to an auxiliary system in my house, as the Gustard x26 Pro is now my 'Main' DAC.
Which one?Put mine on ebay if anyone from the UK fancies one in black
Mine was just delivered as well, hooking it up tonightMine just arrived. Listening now. Sounds beautiful on my Focal Solos.
The D90SEWhich one?
