Topping D10 with RaspberryPi4 - display issue 48 Khz
Ceku
Hello,
I've recently switched to DAC10 with RaspberryPi4 combo, to listen Apple Music via Airplay.
The problem is, the DAC10's display is showing a constant 48.0 PCM no matter what quality (ALAC 256 or 24 bits/48 Khz) I listen to on Apple Music:
Do you think it's normal and correct? I know that via Airplay1 it's not possible to reach to 192 KHz but it seems like the Rpi4 is resampling the 44 KHz sound to 48 KHz which does not sound quite good actually... Or am I being silly here? I'm kind a noob actually.
note: If I use the DAC connected to an iPhone or an iPad via an USB cable the DAC shows from 44.1 KHz (yet again for ALAC 256 or 24 bits/48 Khz) to 192 KHz
Please advise.
Thanks!
somebodyelse
Nothing actually, I've installed a Raspian-Lite on the device and followed the instructions here:
The software would be raspbian lite and shairport-sync then. I didn't see anything in the instructions about setting the audio device to use. I don't know what the default audio device is in Raspbian lite, but I think it used to use dmix so that multiple applications could play at the same time, and that would resample everything so that it could mix the different streams. You can list the available audio devices using the command
Code:
aplay -L
The ones beginning hw: or plughw: use direct access to the device rather than going through mixing.
Look for the config file shairport-sync.conf with is probably in /etc/ or /usr/local/etc/ - it should have a section starting with 'alsa =' containing a setting for output_device where you can tell it to use one that isn't mixed. The mixer_device and mixer_control_name are to tell it what to use for volume control.
Another possibility is that you enabled shairport-sync's DSP
phofman
Raspbian lite uses pulseaudio, like all other debians/raspbians (pulseaudio being mentioned many times in https://downloads.raspberrypi.org/raspios_lite_armhf/release_notes.txt ). IMO the audio runs through PA which runs at a fixed frequency. I do not see any discussion of pulseaudio in the linked tutorial https://www.jeffreythompson.org/blog/2020/04/29/build-an-airplay-receiver-using-raspberry-pi/ , meaning all players are most likely set to "default" alsa device which typically routes to pulseaudio through the alsa pulse plugin.
kchap
Melbourne, Oz
Hello,
Please advise.
Thanks!
What software are you using? I know MOode and Volumio have fixed Bit Rate options but by default they usually output the at the source Bit Rate.
kchap
Melbourne, Oz
I missed the previous replies :facepalm: I think you would have a better chance with MOode or Volumio; they both support Airplay. I use Volumio but whatever you like. Your On/Off script would need changing to work in the MOode/Volumio environment, but you have a reasonable chance of making work.
I suggest your download the SW, write to a fresh flash (so you can keep your current OS and config) and give it a go. Worry about the On/Off script later.
sq225917
Don't confuse bit rate with sampling rate. Your dac displays the sampling rate, not the bit rate. Software players often display both.
somebodyelse
I think the changelog is shared with the non-lite version - it also mentions all sorts of other GUI things that the lite version shouldn't contain, like chromium. https://downloads.raspberrypi.org/r...7/2022-04-04-raspios-bullseye-armhf-lite.info doesn't show PA being present and the tutorial doesn't mention installing it, though I suppose it could be pulled in as a dependency. Usually if you want it available system wide for use by daemons like this you need to change the config too. I may be wrong though - I haven't used Lite in a while.
phofman
Good catch. That means dmix is configured on the default device, with the same result. Since that airplay tutorial never mentions any alsa device configuration, IMO it's reasonable to assume the default is used.
mattanderson
I'd recommend piCorePlayer, as well. It runs in memory and has an option to install an Airplay plugin.
Ceku
Ceku
Code:
aplay -L
I see the following when I check on Pi:
output
hw:CARD=D10s,DEV=0
D10s, USB Audio
Direct hardware device without any conversions
plughw:CARD=D10s,DEV=0
D10s, USB Audio
Hardware device with all software conversions
It seems that D10 is already a direct hardware.
And I don't recall any Shairport DSP; how to check if its enabled or not?
phofman
I do not understand your log - it mentions two devices - which one is actually being used? Most players use the "default" device if the device is not specified explicitly.
The alsa-base.conf config just changes cards' numeric IDs, not important if you use the card name (D10s).
Ceku
Ceku
Here under what I get full when I check via aplay -L
(I'm currently getting the sound via Topping D10s)
Code:
sysdefault
    Default Audio Device
default
output
hw:CARD=D10s,DEV=0
    D10s, USB Audio
    D10s, USB Audio
sysdefault:CARD=D10s
    D10s, USB Audio
front:CARD=D10s,DEV=0
    D10s, USB Audio
    Front output / input
surround21:CARD=D10s,DEV=0
    D10s, USB Audio
    2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=D10s,DEV=0
    D10s, USB Audio
    4.0 Surround output to Front and Rear speakers
surround41:CARD=D10s,DEV=0
    D10s, USB Audio
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=D10s,DEV=0
    D10s, USB Audio
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=D10s,DEV=0
    D10s, USB Audio
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=D10s,DEV=0
    D10s, USB Audio
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=D10s,DEV=0
    D10s, USB Audio
    IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=D10s,DEV=0
    D10s, USB Audio
    Direct sample mixing device
hw:CARD=Headphones,DEV=0
    bcm2835 Headphones, bcm2835 Headphones
plughw:CARD=Headphones,DEV=0
sysdefault:CARD=Headphones
dmix:CARD=Headphones,DEV=0
hw:CARD=vc4hdmi0,DEV=0
    vc4-hdmi-0, MAI PCM i2s-hifi-0
plughw:CARD=vc4hdmi0,DEV=0
sysdefault:CARD=vc4hdmi0
hdmi:CARD=vc4hdmi0,DEV=0
    HDMI Audio Output
dmix:CARD=vc4hdmi0,DEV=0
hw:CARD=vc4hdmi1,DEV=0
    vc4-hdmi-1, MAI PCM i2s-hifi-0
plughw:CARD=vc4hdmi1,DEV=0
sysdefault:CARD=vc4hdmi1
hdmi:CARD=vc4hdmi1,DEV=0
    HDMI Audio Output
dmix:CARD=vc4hdmi1,DEV=0
Ceku
Ceku
Just recently found and applied the following solution:
sudo nano /usr/share/alsa/alsa.conf defaults.pcm.dmix.rate 44100 [I](default was 48000)[/I]
Now the DAC shows 44,1 KHz but the sound is not there.
What I do here could be 44 Khz resampled to 48 KHz and then back to 44,1 Khz?
phofman
That just changes the common samplerate for your "default" device. IMO you want to configure your playback app to use "hw:XX" (or plughw:XX) instead of "default".
Ceku
Ceku
I'm lost...
I already have the following; there I understand that D10 is already the default output device, am I wrong?
output hw:CARD=D10s,DEV=0 D10s, USB Audio Direct hardware device without any conversions
phofman
Command aplay -L just lists all available output PCM devices. The menu in alsamixer just selects which card the running instance of alsamixer will control, it has nothing which choosing a device for your player. You need to tell your player software which device to use. You can tell what software has opened your audio device with
sudo lsof /dev/snd/*
Ceku
Ceku
Yet again, it seems that it's D10:
By considering the following line-up:
Ceku
Ceku
Installed Volumio, and its back to normal: 44,1 KHz.
Problem solved... I guess.
