TIDAL is NOT Worth it! Listening Test
pkane
North-East
Recording is trigered when the level reaches -50.
Both are set into 16/48.
I can try with a longer one, but if I can listen to it, it is that different on all the track.
Post the matched spectrum comparison plot from DeltaWave. There is a small clock drift but DW corrects for that.
Soniclife
I'd try 16/44 throughout, I had problems getting a deep null before I did that. It's also possible one of the players resamples to match the sound card setting as it knows Windows is crap at it.
mvil
mvil
Exactly the same.
Plus if i just put a picture of the spectrogram (recorded at 44.1) for the area that really sounded differently and made me start all of this study
Tidal on yellow, spotify on green
Just look how much stronger is the 10k-15k range (both files have the same level)
Soniclife
Exactly the same.
So the rest of the track is closer?
How do other tracks compare?
gustavjung
Hey guys,
What is the best way to rip output of different streaming services like Tidal/Spotify/Deezer/Amazon?
It's just for AB testing. Will recording of system audio in Audacity work for this?
A long time ago I did a comparison but a volume match was done only by ear. Now I want to repeat the test in a foobar ABX comparator and match volume levels by a multi-meter.
folzag
Hey guys,
RE: Volume match. Both Amazon and Tidal have albums with test tones in their library.
gustavjung
@folzag thanks, I thought about it as well.
Could you confirm please that if I record streaming audio with Audacity as a system audio there won't be any difference in sound compared to a case if I extract the source tracks from streaming services from urls/downloaders etc?
folzag
Sorry, not an expert on that half of things.
I can say from engineering first principles that if your ADC is of equal or higher precision than your DAC, and your DAC is of equal or higher precision than your program stream, you would be able to capture any differences between program streams.
