Mivera
- Thread Starter
- #181
It will be interesting to try, but I have never had any issue with PCM.
Keith.
You won't have an issue with PCM with this DAC either, you will just get better sound when it's up sampled to DSD. But the beauty is you're free to choose. Whatever sounds better to you is the method you can use.
The Mola Mola DAC also up-samples PCM to a DSD like format as well. Same with the dCS vivaldi when the upsampler is used. The Rossini does it internally. The PS Audio direct stream up-samples all PCM to DSD with an internal FPGA, and then uses low pass DSD filters in the FPGA for the DSD. All of the EMM labs/Meitner stuff does the same.
So if you have ever listened to the above DAC's, you have heard PCM up-sampled to DSD.
