outerspace
- Joined
- Aug 18, 2020
- Messages
- 111
- Likes
- 78
I have posted the topic about difference in sound between headphones equalized to one target. If you equalize headphones precisely to one target or to each over and if they not have very much distortions they will sound very similar or most probably the same. You can listen interview of Sean Olive who made similar experiment with same result: "people couldn't really tell the difference between actual binaural recordings of headphones and their only frequency response simulations". So "soundstage", "spatialness", "dullness", "speed" - you name it - seems like all this things are just characteristics of frequency response. If you made artificial ear recording of open headphones and in-ear headphones equalized to them and then compare them with equalized source audio, when all three most probably will sound the same. You can also just pre-equalize recorded headphones to flat and then compare recordings with the source. It would be very interesting to see such test in good realization available for public.
But each time I tried to equalize my headphones using frequency response published on internet resources I don't get good results. Rting, innerfidelty, oratory1990, etc - nothing worked good enough. Maybe it's due to my perceived FR differs from measured ones on rigs. Maybe due to manufacture tolerance. I don't know. But I found a way to copy any FR with amazing result. I was translated frequency response of my open over-the-ear headphones to in-ear by using Y-splitter that split signal from amp to two 3.5mm output. Each output have only one channel - left or right. I insert in-ear earphone to my left ear only and put on open over-the-ear headphones. Then connect both to Y-splitter. So when I play sine wave by generator I hear it only from left cup of my open HP and right in-ear earphone. Then I center this signal on a whole audible range by modifying right channel only (in-ear earphone only) with 31-band equalizer (I used Equalizer APO). I can easy hear left/right channel imbalance on sine signal with accuracy up to ~2-3 dB (depends of frequency range). So I equalize right in-ear to left over-the-ear with 31 band EQ, each frequency at time. If I can catch some additional audible difference I compensate it by parametric EQ. But there is can be a problem is phase differences between L and R on frequencies below 1 kHz. I found method to fix it. Sine generator that I used (SineGen) have phase regulator too so I can tune phase for accurate FR judgment. After equalization I can translate FR from in-ear to any other headphones in similar manner. In this way I can make individual FR copy of any HP. It's not precise, but very good. Method consider my own perception of sound - my pinna and ear canal resonances, etc. Surprisingly, resulted equalization are differs much from FRs published on any internet resources and gave me amazing result. Hope you can get interesting results too if you try it.
UPDATE: You can translate sound of speakers in treated room (studio for example) to headphones by using free software called impulcifer and in-ear mic. After that you can translate obtained personal perceived frequency response from headphones to any other headphones. So it should give similar result to Harman curves but individualized personally for you.
