32,000 nits – luminance of white card illuminated by sunlight+skylight at noon on a clear day
320 nits – luminance of diffuse white rendered by a typical consumer TV
32 nits – luminance of typical diffuse white in cinema
3.2 nits – the light from a single candle at 1 foot distance
No TV is capable of this dynamic range. I'm not even sure we have cameras that can capture it.
I recently had the opportunity to attend a workshop with Charles Poynton, a renowned mathematician and video expert. The informal workshop took place in New York with just a few others, providing a great opportunity to listen and discuss hot button issue around High Dynamic Range (HDR). Poynton...
www.insightmedia.info
And then on the PQ EOTF curve.
by Chris Chinnock, Insight Media This topic of discussion started as an email thread in the HDR work group of the International Committee of Display Metrology (ICDM) and then sparked a long discussion in the recent face-to-face meeting in Mt. View, California. Per agreement with ICDM, they...
Modern TVs use a lot of processing, including curves, including noise models, to deliver the picture.
The issue as I see it is that TVs are mass market devices. The most expensive TVs are usually about furniture and decor and aren't necessarily the best performers. As it is with the most expensive speakers. However, with speakers you have full access to the same tools that engineers use in studios to do their work, and they are relatively inexpensive, easy to setup and play.
With TVs, mastering monitors run tens of thousands of USD and the very best are not available for casual purchase at all. Most have fairly small displays as well, but are heavy and thick. Even if you do buy one, and I was considering doing just that to avoid the panel lottery and reliability issues, these are professional tools, and not consumer-friendly. As far as I know you have to manually select colorspace and other elements when using them, and they have no HDCP compatibility, and usually require special connections.
The more technical consumer will not be able to afford good display measurement gear, while excellent lab-worthy measurement microphones, although not cheap, are affordable.
Say you do measure the TV. Calibration only goes so far and some processing features are not open to be manipulated.
If there was ever an example of gatekeeping, it's with TVs.
Fortunately or unfortunately I've done enough work to understand display flaws, and the only conclusion I've reached is that I would rather be slightly grumpy as I watch a cheap display then buy an expensive TV I would consider artifically crippled by mass market considerations and manufacturing.
Maybe it's why I prefer audio.
