Yes ,I,ve some 24/96 contents. When playing them by Foobar2000, if set output depth as 24, the system will report an error. Besides, there is no 24-bit option in the Format tab for the speakers either.
In fact, I found this guy has the same problem with me
https://darko.audio/2021/02/psbs-alpha-am5-powered-loudspeakers-are-a-600-solution/ . As he said "Let’s begin with a technical issue. Using a Raspberry Pi 4 running Ropieee as a USB streamer, Roon automatically converted 24-bit data to 16-bit data before sending it on to the AM5 even though the AM5’s specifications state that the USB input can handle 24-bit/48kHz data.
While PSB claims a 24-bit/192kHz limit for Toslink, I was only able to play 16-bit data without issue. When attempting to playback hi-res, 24-bit music via Toslink, the AM5 went silent and the status LED on the left AM5 would go into error mode, blinking red. Limiting data to 16-bit from the Toslink streamers to the AM5 using Roon’s Device Setup options solved the problem.
As such, I was only able to review the AM5 streaming 16-bit data. Despite repeated requests for comment on this issue, my contact at PSB remained schtum."
