Speakers with low distortion at high SPL
Fluffy
What speakers demonstrate low harmonic distortion at high DB SPL? By high I mean something like the 96 DB that amir uses, that usually leads to worse performance due to woofer break up and other phenomena. What characteristics should a speaker have to play cleanly at high SPLs? Large woofers? A number of drivers per frequency range? Dividing the spectrum among more drivers (=more crossover points)? Horns? Specific woofer materials?
hardisj
Reviewer
North Alabama
Generally speaking, you're going to need multiple, larger woofers and/or higher sensitivity speakers with more power handling capability.
Vintage57
Ontario, Canada
Th JBL M2, the Neumann KH420, are 2 that come to mind.
if you included horns, there are many.
A800
Exponential horns.
Focal.
aac
Efficiency.
Cooling of voice coils.
You can check cinema loudspeakers to see what you need to play at high SPL
Here is example of what you need to play loud https://jblpro.com/en/products/5742
You can observe their catalog on cinema speakers and you'll see how it is achieved
For even more SPL you can check concert equipment like line arrays - the idea is instead of using large horns to stack A LOT of speakers in a configuration needed.
CDMC
