You should always have the mic steady, ideally on a stand with a long boom to minimise reflections. If you're doing a listening window measurement,then the microphone is moved between measurements, but kept stationary for each individual sweep.
You should also always use a calibrated microphone as the errors can be several dBs at any frequency. If you're only setting up subwoofers, an uncalibrated mic is OK, but for setting up equalisers or measuring loudspeakers, calibration is necessary.
For distortion, one on-axis sweep is fine.
S
S
