ehabheikal
- Joined
- May 22, 2020
- Messages
- 672
- Likes
- 326
Has anyone gotten this to work with ldac. They said it was going to be in a software upgrade and i tried upgrading but still nothing
Normally the Soncoz SGD1, like any other dac, would be better to connect it with pc using cabled digital inputs (coaxial, optical, usb) if no other for allowing the best audio quality. The bluetooth input is intended for temporary use with portable devices, like smartphone or tablets (when they act as a source for the dac). Aniway it could be also a limit of the bluetooth dongle or bluetooth card on your pc, that don't let you connect two or more different devices ; or a settings problem on windows.Good day everyone. Soncoz support doesnt answer to me so Im trying to ask here if anyone could give some advice.
I recently bought Soncoz SGD1. But. Im using Windows 10. SGD1 cannot connect bluetooth before I remove all other bluetooth devices from windows. Then I can connect SGD1. Now that I want to use my other Topping Bluetooth dac/amp (dx3 pro+) and my active speakers with bluetooth again I have to remove SGD1 from windows and create bluetooth connection from the start for both Topping and for speakers. And then next time I want to use SGD1 again with bluetooth I have to remove everything else before windows lets SGD1 to get a connection. SGD1 cannot exist in windows together with anything else bluetooth, not even a keyboard. What to do?
Yes I know about sound improvements from different methods but better not confuse this more with that topic.Normally the Soncoz SGD1, like any other dac, would be better to connect it with pc using cabled digital inputs (coaxial, optical, usb) if no other for allowing the best audio quality. The bluetooth input is intended for temporary use with portable devices, like smartphone or tablets (when they act as a source for the dac). Aniway it could be also a limit of the bluetooth dongle or bluetooth card on your pc, that don't let you connect two or more different devices ; or a settings problem on windows.
I will try to connect my Soncoz to the pc with bluetooth to see if it gives problems with other devices; I will let you know.Yes I know about sound improvements from different methods but better not confuse this more with that topic.
What kind of settings you suggest I should change from Windows? Ive been through basically anything I can think of.
Note that Windows has no problem to connect more than one BT device. (unless its Soncoz) I always have dx3pro+ and BT speakers and BT keyboard without any problem. Now I bring Soncoz to the mix and suddenly its the one and only Win 10 can accept.
I tinkered a bit with the pc and the dac, but my situation is opposite to yours: I have three source devices (2 Android smartphones, 1 Windows PC) towards a single dac.I will try to connect my Soncoz to the pc with bluetooth to see if it gives problems with other devices; I will let you know.
The problem is def. with the Soncoz, not Windows. I had a chance to try it with my brother's laptop and didn't work there either. He said he's never seen bluetooth to behave like that. Soncoz takes control the bluetooth system so deeply that device connected after Soncoz will also be named Soncoz in Windows. I now have Soncoz totally removed and Topping dx3pro+ paired with Win10 and Win claims in setting and in bottom right speaker pic audio section that it's actually Soncoz. I might try and wait Win11 and to see if there's any luck with that.I tinkered a bit with the pc and the dac, but my situation is opposite to yours: I have three source devices (2 Android smartphones, 1 Windows PC) towards a single dac.
I used a bt dongle connected to a USB port (the pc doesn't have a bt module): after half an hour of trying I managed to set the dac as output device, and it worked.
But, for example, if I tried to connect to the dac with the smartphone I succeeded (deactivating the connection from the pc) but I had no audio output; i had to turn the dac off and on again to restore the audio stream.
With the older smartphone, even in the past it struggled to connect and sometimes I had to redo the pairing.
Let's say that the Soncoz bt interface is not exactly "smart ".
But I have read on the net of similar problems also with the Arcam dacs: the bt it's considered an optional or an extreme solution for connecting DACs, regardless of brands and models.
By default, I connected mine with a 5m. USB cable: it works flawlessly, but I plan to take a notebook to place in the audio component rack and use shortest cables.
Aniway, you could also post your question on the Microsoft Community web page, they are more knowledgeable than me in these things.
Yours, as mentioned before, seems to be more a problem of settings on the pc side, rather than of a dac's issue.
It sounds really strange to me too, that bt behaviour.The problem is def. with the Soncoz, not Windows. I had a chance to try it with my brother's laptop and didn't work there either. He said he's never seen bluetooth to behave like that. Soncoz takes control the bluetooth system so deeply that device connected after Soncoz will also be named Soncoz in Windows. I now have Soncoz totally removed and Topping dx3pro+ paired with Win10 and Win claims in setting and in bottom right speaker pic audio section that it's actually Soncoz. I might try and wait Win11 and to see if there's any luck with that.
When there was talk earlier about wired sound quality being superior I want to mention that I also use this usb most of the time, BT is for late at night sessions when I wanna pull the signal to another amp on the other side of the room and drive Soncoz wireless.
Not even till nowProbably, by now , you will have already solved it, anyway : have you tried to install the Thesycon drivers ?
They are those recommended by the manufacturer; you can find them on this page : https://www.soncoz.com/product-item-2.html (clicking on the tab "Material" , after the pdf files of the manuals).
. yes i intstalled that thesycon driver. Been communicating with soncoz via email but just circling around the language barrier.Hi.Not even till now. yes i intstalled that thesycon driver. Been communicating with soncoz via email but just circling around the language barrier.
already create one, but no one seems to have same problemHi.
Try to create a new thread entitled as the driver issue.
This one is a bit old, nobody follows it anymore, not even ben1987.
The LOGO is supposed to represent a PINE CONE:The logo immediately reminded me of a person in a straight-jacket.
Just like the MadMan Entertainment logo:
Also looks like a closed fist.
Their translation leaves something to be desired. My wife is Chinese & she translated it as you say. So... I guess that sometimes we have to interpolate what it is that they mean."Committed to reducing every detail and dynamic of audiovisual works"
they mean "Committed to REPRODUCING every detail...."
right? right?
The pine cone actually made me guffaw...
I wonder who thought them (pine cones) to be a great fire starter first? It sure is a great idea & seems to be well known any place that there are trees that produce them.Pine cones make good firestarters.
I've said it before, but their logo reminds me of this straightjacket dude:
Ok, so major breakthrough. This ALREADY works. Simply get an Apple TV, go to Remotes and Devices, Volume Control and then Learn New Device Use your Soncoz remote to tune it and then you can through it away!
PINE CONES? Great fire starters!Pine cones make good firestarters.
