SMSL D-6s Balanced DAC Review
Rate this DAC:
    Votes: 9 2.4%
    Votes: 5 1.3%
    Votes: 25 6.6%
    Votes: 338 89.7%
Tangband
Sweden
Amirm said: there is no trembling in all three interfaces". And that's the main thing. I take his word for it .
Amirm uses lab gear with the measurements of spdif - with probably lower noise than a WiiM pro or similar, and no ground loops . The absence of a transformer at spdif is all about cutting cost.
The correct way to use rca spdif is to have a transformer either at the sending side or at the receiver .
There are no issues using toslink ofcourse
Toku
Japan
Only some DAC products, such as Topping's D70s D70Pro DX7Pro D90, are equipped with a pulse transformer for S/PDIF galvanic isolation. DDC products D10S/D10B are properly equipped with a pulse transformer as the responsibility of the transmitter.
Since it is an inexpensive component, I think it would be a good idea to actively install it on the S/PDIF receiving side.
I have yet to see any SMSL product equipped with a pulse transformer for S/PDIF galvanic isolation.
woof!
thank you! Then it's Topping E50 for me, I think.
yeah, whichever dac you pick most likely will get you the same sound quality. so, picking the one that have the most feature you want/need and have the lowest price is probably the best decision.
Spocko
Southern California
This is a review and detailed measurements of the SMSL D-6s balanced stereo DAC with Bluetooth support. It was sent to me by the company and costs US $199.
I was pleasantly surprised with the new industrial design which while minimalistic, manages to impress with its modern style. Love the matt diffuser in front of the white LEDs. And the elevated panel gives a distinct and dare I say, luxury feel. A remote control is provided which makes navigation very easy.
Very nice to have built-in power supply in such a small package:
SMSL D-6s DAC Measurements
Let's start with our usual dashboard with level adjusted to near 4 volts using XLR output first:
Distortion products are at -140 dB! Incredible. SINAD as a result is dominated by noise, and landing the D-6s in our top 20 chart of all DACs tested:
Even RCA output is impressive and fully audibly transparent:
Output can go to 5 volts using XLR giving us a bit more performance still:
As noted, SINAD is determined by noise since distortion component is so low:
For compatibility with stereophile magazine measurements, here is the 60 Hz performance:
Despite having a "punishing" load of 600 ohm as JA calls it there, D-6s sails with distortion at whopping -120 which I am confident bests anything stereophile has ever tested.
Back to our own tests, linearity is nailed:
As is jitter across all three interfaces:
Multitone performance makes the company proud:
We are some -135 dB in some of the frequency range!
EDIT: Forgot to post the IMD test:
Here are the usual filter and frequency response tests:
Using default F2 filter, we get excellent performance in our wideband THD+N with a slight rise at the upper end:
I pride myself in always finding something to complain about in a review but I have nothing for you here. Price is right. The look is right. And performance is top notch regardless of price. I always recommend balanced DACs and here is your chance to get one without any compromise.
I am happy to recommend the SMSL D-6s DAC.
Manufacturer Specifications:
  • Inputs: USB, optical, coaxial, Bluetooth
  • Outputs: RCA, XLR
  • THD+N: 0.00006% (-123dB)
  • Line output amplitude:
    • XLR: 5Vrms
    • RCA: 2.5Vrms (1.13Vrms)
  • Output impedance: XLR: 100Ω
  • Dynamic range:
    • XLR: 129dB
    • RCA: 126dB
  • SNR:
    • XLR: 129dB
    • RCA: 126dB
  • USB transmission: Asynchronization
  • USB compatibility: Windows 7, 8, 8.1, 10, 11 (needs driver); Mac OS X 10.6 or later, Linux (driverless)
  • Sampling rate and bit depth:
    • USB:
      • PCM: 44.1-768kHz (32bit)
      • DSD: 2.8224-22.5792MHz (1bit)
      • DoP: DOP256
    • Optical/coaxial: 44.1-192kHz (24bit); DoP64
  • Bluetooth version: 5.1
  • Bluetooth codecs: SBC, AAC, aptX, aptX HD, LDAC
  • Power consumption: <10W
  • Standby power: <0.5W
  • Size: 150x42x128.5mm (WxHxD)
  • Weight: 1.57lbs (0.71kg)
As always, questions, comments, recommendations, etc. are welcome. Click here if you have some audio gear you want me to test.
Unbelievable price for balanced XLR DAC, I'm frankly stunned! Where will we be in 18 months at this rate?
brunes
Does the dial on the front act as a volume control and is there a good reason why I can't go straight into a power amp without a preamp with this DAC?
Catsmeow
I never run any setup that doesn't have a physical attenuation prior to being amplified. The risk of blowing speakers, headphones, etc is a thing.
Abrise
French Expat in Bangkok
You need a passive volume knob in between your DAC with digital volume and an amplifier without volume. @amirm has tested a few. Before I got this knob, I had expensive loudspeakers destroyed by teenagers. Set this knob so that when your digital volume is maximum your loudspeakers are safe.
PyramidElectric
As long as the DAC works properly, i.e. it remembers the volume setting (and given that in other SMSL DACs like the DO100 this works flawlessly, i'm going to assume they know what they're doing here), then the DAC works exactly like a passive volume control/pre-amp, meaning you absolutely do not need one. Sure, the DAC could fail, but so can a pre amp...
PyramidElectric
Not sure.... Have you ever had women or teenagers at home ? A passive knob adds a level of security.
Yeah I'm not sure you're understanding this, but if you set the DAC volume at (for example) 50% it stays at 50% no matter if you turn it off, switch inputs, whatever, it only moves from 50% if someone turns the volume control, exactly the same as with a passive pre amp.
staticV3
Or not:
ampguy
US
Looks good. I have an earlier version, the d6, which uses TRS, has AKM, and I think earlier usb controller. But I don’t have any issues with the old one.
ampguy
US
I always keep my dacs on full. Just feels safer to me. I’ve never had a preamp volume fail.
Toku
Japan
D-6S has a similar model number to D-6, but is completely unrelated to D-6. D-6S is rather a model planned and sold by Shenzhen Audio, which originated from the DO100 planned and sold by Aosida.
Esprit
Italy
Same measurements?
I can't find them here on the forum.
