solderdude
You tease us. Those 2 being (especially the latter)? Is the latter a planar?
1st = HD250 Linear II
2nd = Philips X2HR (non modified)
Any guess, how much the HD 660s differs from this?
drop raised the prices a while ago, now it's $220 + shipping.Is it confirmed that the massdrop 6xx is basically the same exact thing? That one is only $200
have they published this or any other of the 650/6XX measurements? curious.5: I have been told by someone that contacted Sonarworks and he claims he was told HD6XX do not measure exactly the same as HD650 from the same time period.
Why ?
6: What makes it so that only Amirs setup is conclusive where there are more people around measuring with similar or the same setups ?
Amazing how good those Philips 'phones are. Satisfying bass from a low-power [Fiio M3K] DAP. Doesn't need EQ for decent bass. Reminds me a lot of the original Large Advent. 90% of the performance for 30% of the price. Doesn't go all the way down, but it goes more than far enough for most music. Not the cleanest, purest treble, but more than clean enough.1st = HD250 Linear II
So unless the 660s has significantly lower distortion once you start EQ or you really need the lower impedance (why? 150 still a bit high for phones to blast through), the smart money is on the 6xx if available to you. Certainly not worth side grading a 600/650 for
Same as his set up for 650 I would have said. Mechanically identical, no?I own same setup.
Curious to see Amir's (or members) Parametric EQ for Drop 6xx.
Of course few of us have the same auditory test results!
Yes, I think so, according to Oratory's measurements the HD600 tracks the Harman Curve more accurately than the Diffuse Field (even though they are marketed as Diffuse Field headphones):
Harman:
https://www.dropbox.com/s/dm0m6u3s3b4zqzl/Sennheiser HD600.pdf?dl=0
Diffuse:
https://www.dropbox.com/s/upib5ztmte79qpl/Sennheiser HD600 (Diffuse Field).pdf?dl=0
So as you were alluding to, it could well be that even though they were basing some elements on the Diffuse Field, that through "ear tuning" development they ended up closer to the Harman Curve.
I agree about the sub 90Hz point you made, I imagine it's hard/impossible for open-backed headphones that don't contain any active processing (EQ) to follow a flat extended low bass response, let alone a Harman bass boost......but that's the beauty of EQ!
They do however track the Harman Curve remarkably well.
Haha, don't expect much. I auditioned the hd820 in store couple of times, it is very pretty, comfortable, but the sound has some serious issues.curious to see how amir eq the hd820. I had one but too sharp for my ear. feel a little headache...
but it feels very comfortable...
How much was this little dac amp again? It was an amazing value. Grace sells it themselves now for 730$ Canadian... At this price not so much, but I just love the form factor, design, very respectable power, line outs small enough to carry in the laptop bag, I'd like to find something like that at a decent price.Nice review @amirm. I have a pair of the Drop version, HD6xx. They are my daily drivers so to speak. I use equalizer APO on a Dell notebook and a Grace M9xx DAC. It's a great bedside setup and travels well.
It's no wonder this set of cans is so popular.
It gets smoothed to 12PPO.
It's [the formula] evaluated at the frequency range 50 Hz to 10 kHz. They [Harman] recommend evaluation of at least 100 points spaced logarithmically in that range (although normally much more points are used, I use 500 points spaced logarithmically from 10 Hz to 20 kHz).
This are literally 45 years old one's.Amazing how good those Philips 'phones are. Satisfying bass from a low-power [Fiio M3K] DAP. Doesn't need EQ for decent bass. Reminds me a lot of the original Large Advent. 90% of the performance for 30% of the price. Doesn't go all the way down, but it goes more than far enough for most music. Not the cleanest, purest treble, but more than clean enough.
