Seeking help with a Threaded Banana Chassis Mount search
Corn Fed HIFI
Iowa
Hi, looking for a replacement cage to chassis fastener for my Shuguang I-12 tube amp.
I have searched Pomona, Cinch, Keystone and Mueller offerings in hopes of finding an electrical connection banana plug that would suffice.
The banana shaped fasteners actually wobble +/- 2 degrees and have the following measurements: 25mm overall length, 5mm shoulder, 14 mm banana length, 3mm tip, 4mm banana width, 8mm nuts.
Open to suggestions.
Thanks!
You may be able to buy most any banana plug and replace whatever shell it comes with with a nut of the right size to turn it into a chassis mount.
Don, I tried four different bananas that I have on cables and they all too big at the "bulge".
Ah, sorry. Too big to physically fit, or just too tight? Seems like might have been a special run just for Shuguang? Vexing...
Too big to physically fit although I may try cutting off one of the banana bulge strips ... nothing to lose
