Samson Resolv SE6 - worthwhile?
andraleia
I've been looking to buy my first pair of monitor speakers
I do a bit of mixing, for myself and friends, generally in headphones (I know...), and using whatever speakers are on hand to A/B. Recently those were a pair of Infinity RS3s that a roommate was lending me, and now is taking back
In looking to replace them, I've been asking around forums for advice. I get referred frequently to the Kali LP-6, which retail around $300 / pair, and I've seen used for as low as $260 or so
That's still a little high for me, but I was considering it – but *then* I found this deal locally that seems pretty amazing
It's a pair of Samson Resolv SE6 speakers, with Auralex MoPAD Isolation Pads, two IEC power cables, and a 3.5mm to 1/4" cable for $175 total
From my calculations, that all would retail close to $500 new. There are some scratches on the outside of the Resolv, but the speakers look fine. I'm planning to test & pick it up tomorrow
My question is: are these speakers alright for entry level mixing? They've gotta be a step-up from the Inifinity RS3s at least, right? Are they comparable at all to the Kalis? Are they worth the price?
Would love some input :) For reference, I will be almost exclusively using it to mix guitar / bass / drum driven music; no EDM or anything of that ilk for me really
A
andraleia
((I hope this sort of thread is welcome; I looked for rules disallowing it and didn't find any, so I went ahead with it))
AnalogSteph
.de
I wouldn't be so sure about that. Those were not cheap in the early '90s, they sport a waveguide (almost but not entirely unheard of at the time) and they have a decently complex crossover. The Samsons have barely any waveguide at all and as such presumably have wide but not entirely even dispersion.
$175 for a pair of entry-level 6" monitors that are a few years old still seems like a decent deal and should get you started either way, though you would do yourself a massive favor by picking up a Behringer HD400 and two balanced TRS --> TRS or TRS --> XLR cables in addition, or else you will get very familiar with ground loop issues. That goes for most other active monitors as well.
Sal1950
The Chicago Crusher
Central Fl
A
andraleia
I did see the first. I mentioned the LP-6 being what I was considering prior, and that I am now considering these SE6 speakers because of the deal, in my post
The second isn't relevant to me. The 308p is $500 for a pair. That is very, very far out of my price range
A
andraleia
Thanks for the advice. I'm fairly accustomed to dealing with ground issues, balanced lines, etc. - but I'll definitely bear in mind the HD400 recommendation :)
A
andraleia
I don't know anything about the Samsons but a few days ago I posted that Sweetwater has the JBL 305P Mk II's on sale till the end of the month for $119 each with free shipping. That sounds like it might fit right into your budget quiet nicely. I don't believe you can go wrong at this price. ;)
https://www.sweetwater.com/store/de...t&utm_medium=email&utm_campaign=20210202-t1t2
Hmm, okay. I see they're 5-inch drivers; the two I'm really considering right now, the SE6 and the LP-6, are both 6.5-inch drivers for the woofers. I've been told that it's not wise to consider anything smaller if I'm mixing something bass-driven – and as I'm primarily a solo bassist, I would like something that gives me at least some picture of the low-end
richard12511
What about on sale? They go on sale several times a year for $300/pair. For that price, I haven’t seen anything that comes close. 306 and 305 also go on sale just as often. They’ll be even cheaper than that, though not as much of a steal.
Sal1950
The Chicago Crusher
Central Fl
That's proablly very good advice that applies to anything we've discussed. I'd save as much as I could on the speaker, getting something like the 305s and then get a good, reasonably priced subwoofer. None of these little desk jockies under 8" are going to supply much bass for your mixing without a sub. Bet you could find a great used sub for loose change.
