sailor2005
- Joined
- Oct 8, 2020
- Messages
- 127
- Likes
- 178
It's the Havana Syndrome......
Boy. I didn’t hear such a nonsense for a while. It’s hard to imagine why you even joined? Trolling?It sounds warmer than the Arturia Minifuse, maybe there is some sort of subsonic event that is causing me that fatigue.
Same thing happened to me with the Fossi Audio BT20A Pro class D amplifier, maybe i am allergic to chinese products.
I think is not fatigue, probably is due tinnitus than produce the treble with a lot of details in high frequency, how to avoid.? . Trying some warm dacs, some r2r dacs , tube amps, warmer headphones.. the problem now ita to find what of those could fit you.I never understood the term "listening fatigue". Maybe you have anxiety, maybe you are tired, maybe you just don't feel like listening to music at that moment.
Not tinnitus. Tinnitus occurs inside the head and does not have an external source. So called "warm" DACs, tubes or anything of the sort would helpI think is not fatigue, probably is due tinnitus than produce the treble with a lot of details in high frequency, how to avoid.? . Trying some warm dacs, some r2r dacs , tube amps, warmer headphones.. the problem now ita to find what of those could fit you.
So, did we scare away the OP?
I can sell you a SMSL SU-1 for $10.000 problem solved!but you never know with this cheap chinese products and their quality control.
I just noticed I made a boo boo... it should have said "would NOT help"Not tinnitus. Tinnitus occurs inside the head and does not have an external source. So called "warm" DACs, tubes or anything of the sort would help
Only 2 pages of trying to diagnose the unpossible though. Improvement.He needs to buy and return at least a dozen more DACs until he's happy. Maybe.![]()
I'm from Russia. What is Russian mind melter? We don't have that. Probably.it CANNOT is making peoples' heads blow up as if its a Russian mind melter...
I´m using bookshelf speakers.
I think you made a typo in the adresbar... this is Audio Science Review not Head-Fi.What speakers do you use?
It could be a pairing problem, basically it's a combination dac / amp / speaker, for example, using a dac like this that almost all reviews describe as airy and expressive in the treble, with an amp and speakers that are also considerably high in the treble (and which can be exacerbated by resonances, ambient acoustics or a certain level of distortion), can cause this, but the highs alone are not always the case, fatigue and harshness can also happen with the mids, changing this dac for a more ''warm'' one can solve the problem, but it depends on the dac and it would be difficult to choose the right on, the ideal would be for you to have a setup with a more balanced sound without exacerbation, this is certainly the case and obviously considering that you experience the problem you describe..
From my experience with dac and amp, I would say that most entry level class d and bookshelf speakers have a drier and somewhat fatiguing sound and will not sound good whatever dac is used, generally a good dac that presents good measurements is not the problem, I generally say, is because I have a topping e30 and I feel like it never sounds good enough to listen to for hours and hours and has a kind of ''disturbance'' in the midrange (I think), as the treble I always found great, I've already tried using it via USB or optical, on the PC , with streamers, active or passive speakers, different amps and environments, etc., we don't always have good experiences following reviews and measurements, it depends on several factors, today I use the SMSL a300 integrated amp, with the internal dac via bluetooth or usb, I would say which is very decent and good for music and games, at least I no longer have this problem of ear pain, fatigue or harshness that many people suffer. Have you returned the dac yet? I would recommend selling or returning and then buying an SMSL A300, it is one of the best amp/dacs I have ever heard, the price is relatively affordable and the sound is more refined for something in this price range, it has a more neutral sound and '' rounded'', maybe it sounds better on your speakers.
I think you made a typo in the adresbar... this is Audio Science Review not Head-Fi.![]()
