2022-07-21 16:09:39.778564 INFO [src/bin.rs:711] CamillaDSP version 1.0.0
2022-07-21 16:09:39.778738 INFO [src/bin.rs:712] Running on linux, aarch64
2022-07-21 16:09:39.778934 DEBUG [src/bin.rs:754] Read config file Some("/home/michael6/camilladsp/active_config.yml")
2022-07-21 16:09:39.780886 DEBUG [src/bin.rs:773] Config is valid
2022-07-21 16:09:39.781025 DEBUG [src/socketserver.rs:260] Start websocket server on 127.0.0.1:1234
2022-07-21 16:09:39.781368 DEBUG [src/bin.rs:857] Wait for config
2022-07-21 16:09:39.781480 DEBUG [src/bin.rs:890] Config ready
2022-07-21 16:09:39.781972 DEBUG [src/filters.rs:450] Build new pipeline
2022-07-21 16:09:39.781972 DEBUG [src/bin.rs:213] Using channels [false, false, false, false, false, false, false, false, false, false, false, false, true, true, false, false]
2022-07-21 16:09:39.782154 DEBUG [src/alsadevice.rs:903] Buffer frames 1024
2022-07-21 16:09:39.782165 DEBUG [src/filters.rs:355] Build from config
2022-07-21 16:09:39.782272 DEBUG [src/filters.rs:355] Build from config
2022-07-21 16:09:39.782383 DEBUG [src/filters.rs:355] Build from config
2022-07-21 16:09:39.782520 DEBUG [src/filters.rs:355] Build from config
2022-07-21 16:09:39.782629 DEBUG [src/filters.rs:355] Build from config
2022-07-21 16:09:39.782742 DEBUG [src/filters.rs:355] Build from config
2022-07-21 16:09:39.782848 DEBUG [src/filters.rs:355] Build from config
2022-07-21 16:09:39.782955 DEBUG [src/filters.rs:355] Build from config
2022-07-21 16:09:39.783064 DEBUG [src/filters.rs:355] Build from config
2022-07-21 16:09:39.783169 DEBUG [src/filters.rs:355] Build from config
2022-07-21 16:09:39.783271 DEBUG [src/filters.rs:355] Build from config
2022-07-21 16:09:39.783372 DEBUG [src/filters.rs:355] Build from config
2022-07-21 16:09:39.783474 DEBUG [src/filters.rs:355] Build from config
2022-07-21 16:09:39.783575 DEBUG [src/filters.rs:355] Build from config
2022-07-21 16:09:39.783680 DEBUG [src/filters.rs:355] Build from config
2022-07-21 16:09:39.783787 DEBUG [src/filters.rs:355] Build from config
2022-07-21 16:09:39.783919 DEBUG [src/processing.rs:19] build filters, waiting to start processing loop
2022-07-21 16:09:39.785494 DEBUG [src/alsadevice.rs:406] Playback: supported channels, min: 10, max: 22, list: [10, 18, 22]
2022-07-21 16:09:39.785644 DEBUG [src/alsadevice.rs:407] Playback: setting channels to 18
2022-07-21 16:09:39.785836 DEBUG [src/alsadevice.rs:411] Playback: supported samplerates: Discrete([88200, 96000])
2022-07-21 16:09:39.785966 DEBUG [src/alsadevice.rs:412] Playback: setting rate to 96000
2022-07-21 16:09:39.786110 DEBUG [src/alsadevice.rs:416] Playback: supported sample formats: [S24LE3]
2022-07-21 16:09:39.786225 DEBUG [src/alsadevice.rs:417] Playback: setting format to S24LE3
2022-07-21 16:09:39.791250 DEBUG [src/alsadevice.rs:448] Opening audio device "hw:UltraLitemk5" with parameters: HwParams { channels: Ok(18), rate: "Ok(96000) Hz", format: Ok(S243LE), access: Ok(RWInterleaved), period_size: "Ok(128) frames", buffer_size: "Ok(1024) frames" }, SwParams(avail_min: Ok(512) frames, start_threshold: Ok(384) frames, stop_threshold: Ok(1024) frames)
2022-07-21 16:09:39.791433 DEBUG [src/alsadevice.rs:453] Audio device "hw:UltraLitemk5" successfully opened
2022-07-21 16:09:39.791590 DEBUG [src/bin.rs:323] Playback thread ready to start
2022-07-21 16:09:39.883473 DEBUG [src/alsadevice.rs:406] Capture: supported channels, min: 16, max: 16, list: [16]
2022-07-21 16:09:39.883613 DEBUG [src/alsadevice.rs:407] Capture: setting channels to 16
2022-07-21 16:09:39.883720 DEBUG [src/alsadevice.rs:411] Capture: supported samplerates: Discrete([96000])
2022-07-21 16:09:39.883819 DEBUG [src/alsadevice.rs:412] Capture: setting rate to 96000
2022-07-21 16:09:39.883924 DEBUG [src/alsadevice.rs:416] Capture: supported sample formats: [S24LE3]
2022-07-21 16:09:39.884022 DEBUG [src/alsadevice.rs:417] Capture: setting format to S24LE3
2022-07-21 16:09:39.884299 DEBUG [src/alsadevice.rs:448] Opening audio device "hw:UltraLitemk5" with parameters: HwParams { channels: Ok(16), rate: "Ok(96000) Hz", format: Ok(S243LE), access: Ok(RWInterleaved), period_size: "Ok(128) frames", buffer_size: "Ok(1024) frames" }, SwParams(avail_min: Ok(512) frames, start_threshold: Ok(0) frames, stop_threshold: Ok(1024) frames)
2022-07-21 16:09:39.884436 DEBUG [src/alsadevice.rs:453] Audio device "hw:UltraLitemk5" successfully opened
2022-07-21 16:09:39.884591 DEBUG [src/bin.rs:333] Capture thread ready to start
2022-07-21 16:09:39.884694 DEBUG [src/bin.rs:336] Both capture and playback ready, release barrier
2022-07-21 16:09:39.884814 DEBUG [src/bin.rs:338] Supervisor loop starts now!
2022-07-21 16:09:39.884837 DEBUG [src/alsadevice.rs:948] Starting captureloop
2022-07-21 16:09:39.884912 DEBUG [src/processing.rs:21] Processing loop starts now!
2022-07-21 16:09:39.884922 DEBUG [src/alsadevice.rs:850] Starting playback loop
2022-07-21 16:09:39.885295 DEBUG [src/alsadevice.rs:244] Starting capture from state: SND_PCM_STATE_PREPARED, Ready to start
2022-07-21 16:09:39.891988 INFO [src/alsadevice.rs:156] Starting playback from Prepared state
