danadam
- Joined
- Jan 20, 2017
- Messages
- 999
- Likes
- 1,562
Hi
I have RME ADI-2 Pro FS R BE with latest firmware, connected through USB. My pulseaudio is configured with alternate samling rate:
so when I play 44.1 kHz file, the DAC shows internal clock "44.1" and when I play 96 kHz file, it shows "96.0". All fine and as expected. Now, if I open "pavucontrol" (PulseAudio Volume Control) while playing that 96 kHz file, then for some reason the DAC switches its clock to "44.1". PulseAudio still sends data with 96 kHz sampling rate, so it ends up like this (internal clock in bottom right):
Both before and after running "pavucontrol" the alsa and pulseaudio sink parameters are the same:
The system seems to be stuck in this state (i.e. alsa/pulseaudio at 96 kHz, DAC at 44.1 kHz) until I both stop the player and quit "pavucontrol".
This happens on my Debian Testing (kernel/alsa k5.9.0-1-amd64, pulseaudio 13.0) and Ubuntu 20.04 (kernel/alsa 5.4.0-51-generic, pulseaudio 13.99.1).
Also, this does not happen with other DACs (Speaka and Dragonfly).
Anyone experiences something like that with ADI-2?
Code:
default-sample-format = s32le
default-sample-rate = 44100
alternate-sample-rate = 96000
Code:
# /proc/asound/card2/pcm0p/sub0/hw_params
access: MMAP_INTERLEAVED
format: S32_LE
subformat: STD
channels: 2
rate: 96000 (96000/1)
period_size: 44100
buffer_size: 88200
# pacmd list-sinks
* index: 3
state: RUNNING
sample spec: s32le 2ch 96000Hz
