First of all, that doesn’t work, secondly, it would defeat the dynamic loudness calibrationNo problem. Just use ROONs volume control in the ROON-remote.
(Roon->ROPIEEXL—>RME)
Fk room just get volumioI really wish there was a way to operate the volume from Roon.
Roon is great; I run convolution in Roon; that wouldn’t control the RME volume either.Fk room just get volumio
Agree, great device and always sounds good. I got a RPI 4 connected via USB. No shortage of settings and haven't bothered with adjusting anything really.Great product. It took me a long time to decide because of cheaper (partial) alternatives (DACs with digital volume control, audio interfaces, …). But in the end, I think it’s one of these (rare) products you don’t regret purchasing because it’s never annoying: it just works and safely.
Easy to match output levels with your equipment, great performance regardless of the input, useful EQ options, variable loudness, balance, visualization of the input signal, …
Of course we’re reaching the limit of what can be achieved without a touch interface, but the new app to control from a computer or tablet (still have to try) is a nice solution.
Thanks, couldn't see the android one but there are a few generic ones around.ADI-2 Remote for iPad
The RME ADI-2 Remote App is a remote control for the RME ADI-2 Series. The device needs to be connected to the iPad via USB. Settings are transferred from the device to the remote when the app is started and can be conveniently adjusted there. A special editor allows access to all EQ presets...apps.apple.com
But it exists for PC and macOS also
Thanks for the reply. I haven't checked back after the first few days of asking the question, I didn't think I was going to get a reply.They not care because it works. We render all EQs where it is necessary with double precision and/or oversampling. You won't be able to measure THD on them.
I have to say when the treble is on this level +5-7dB the amount of the details are shockingly good And doesn’t sound artifical or forced at all. I just thought it’s a bit too much.Hi All. I just purchased the AKM version of the ADI 2 DAC. I’m using with KEF R3 speakers. These KEF’s (non-meta) can sound quite closed in the top end. In general - even if these are early days yet - I’m happy with the dac, however without any treble adjustment the high frequencies are sounds brutal flat. To hear them in balance with the rest of the freq’s I have to allow at least +5-6dB on treble. Bass is fine at zero. Is anybody have similar treble setting and it’s just fine because in zero settings they should sound flat or do I have the investigate further? Thanks!
I can't imagine someone needing for +5-6dB Treble with KEF R3s. The Frequency Response of the ADI-2 DAC is ruller flat out of the box anyway . Instead, you should check if some EQ is On with somewhat tilted down treble.In general - even if these are early days yet - I’m happy with the dac, however without any treble adjustment the high frequencies are sounds brutal flat. To hear them in balance with the rest of the freq’s I have to allow at least +5-6dB on treble. Bass is fine at zero. Is anybody have similar treble setting and it’s just fine because in zero settings they should sound flat or do I have the investigate further? Thanks!
I use a lot of high frequency shaping. I mean a lot. That's what works for me.I have to say when the treble is on this level +5-7dB the amount of the details are shockingly good And doesn’t sound artifical or forced at all. I just thought it’s a bit too much.
I have the rme ADI 2 fs great DAC. I usually leave it flat (using rpi4 -rme - Yamaha hs80m). Good having those bass and treble buttons if you want to adjust quickly with different sources. Just play around with it and set on whatever you think sounds the best.Hi All. I just purchased the AKM version of the ADI 2 DAC. I’m using with KEF R3 speakers. These KEF’s (non-meta) can sound quite closed in the top end. In general - even if these are early days yet - I’m happy with the dac, however without any treble adjustment the high frequencies are sounds brutal flat. To hear them in balance with the rest of the freq’s I have to allow at least +5-6dB on treble. Bass is fine at zero. Is anybody have similar treble setting and it’s just fine because in zero settings they should sound flat or do I have the investigate further? Thanks!
Yeah that was I thought too. I have a Topping E50 and SMSL SU-1 as well. Others doesn't have built-in tone controls so I have used the wiim mini's eq to lift up the treble a bit. Around +3.5dB what I used there. Wiim mini eq is off now. I've always loved the sharp treble, but when it still not to be harsh or fatiguing, so may be it's just my ears. I still can say that the amount of detail and the quality of the details are way better than on the other too but just surprised how "un-listenable" when the setting is on zero. Settings were adjusted here and there, so I've done a factory reset and the current ones are all my adjustments.I can't imagine someone needing for +5-6dB Treble with KEF R3s. The Frequency Response of the ADI-2 DAC is ruller flat out of the box anyway . Instead, you should check if some EQ is On with somewhat tilted down treble.
