Can you hear this hump, is it even an issue?
I don't know but i never claimed it is an issue.
Just asking a technical query doesn't mean there is a audible issue.
It's been discussed a lot on this forum so is a fair technical question imho
So I can understand that if you get an ESS version, you want no ESS hump.
It will only show you +13dBu, you need to add +6 for XLR connection (in your head, won't show on screen....)Connected this to the pc, turned out to be a time waster.. will have to research in depth how to use something similar to Tidals's exclusive mode.
Works on the iFi and just simple. I didn't actually get it to use at the PC so all good. Just want to quickly know:
- settings/mode for pre-out aka full vol for RCA out to headphone amp.
- best settings for XLR (only seems to go to +13dBu not +19??
thanks
ps. I would expand this thread to archive view and search, but can't even do that..
thanks
yes I've got it, nothing really says about toggling displays for the analyser, jsut start pressing buttons.
It depends on their sensitivity. Genelecs are very sensitive at their default settings (100 dB @ -6 dBu), so I use the lowest output level for them.Thanks, so you recommend setting to +13dBu for active monitors?
ok I've got Yamaha HS80M: Input Sensitivity/Impedance = -10 dBu/ 10 k-ohmsIt depends on their sensitivity. Genelecs are very sensitive at their default settings (100 dB @ -6 dBu), so I use the lowest output level for them.
Probably best and easiest to leave things on the default setting (except spectrum analyser on amber )
Thanks for that, will definitely look into it over the weekend and see what seems best. DOn't get me wrong it's great anyway, just deciding on the best volume settings for the monitors/dac. My mate has only used it a handful of times and hasn't stuffed around with it but did a factory reset for good measure . the monitors are about at 1:30pm , will sus it out though.For gain/level matching you ADI-2 DAC to your monitors have a look at this post section Case 2:
If you can't reduce the level enough on your monitors you might need passive attenuators:
Level mismatch solutions - fixed and variable attenuators (Page 1) — Tips & Tricks — RME User Forum
Level mismatch solutions - fixed and variable attenuators (Page 1) — Tips & Tricks — RME User Forum —forum.rme-audio.de
In any case, since you bought your ADI-2 DAC used I suggest, as above, that you reset it to default settings. Do the same for your monitors as on the ADI-2 DAC you have PEQ as well as dynamic loudness and B/T tone controls.
I have the RME adi-2 FS. I checked oratory1990s database and he has a list specific for rme adi-2. But he shows 10 band eq where RME ADI 2 FS and ADI 2 pro only support 5 band. So how is that possible?
Why do he list 10 band eq for rme adi-2 fs when such a feature don´t exist?
What does the manual say, 7 bands? Assume it is per side?
All this sounds interesting, I've got some spare DT990 lying around i could use our of the ADI- headphone output in the living room. They have a slight 10k kHz harshness that isn't so nice. Nice if could set the eq for headphone amp output only
Ether c Flow. He list 10 band för Flow och Flow 1.1 https://www.reddit.com/r/oratory1990/wiki/index/list_of_presets/#wiki_list_of_presets_for_rme_adi-2
C Flow 1.1 is the old modded ether c and c Flow the current or other way around?
I found that other reddit list as well.. shame your list doesn't include many headphones - keen to try for the DT250 / DT 990 Pros.The link you provided is not for the RME ADI-2 DAC. It's probably why I accidentally end up at the full EQ settings.
Try https://www.reddit.com/r/oratory1990/wiki/index/list_of_presets_rme_adi-2 instead. Unfortunately you're going to be disappointed that there is nothing there for the Flow.
Ah I see.The link you provided is not for the RME ADI-2 DAC. It's probably why I accidentally end up at the full EQ settings.
