No need to replace the power supply.....Dear @amirm :
Could you tell me what kind power supply you are use for RME ADI-2 DAC FS? Thank you.
I guess he's using the standard one that comes with the device.Dear @amirm :
Hi @cses050108 have a wander over to the RME forum, they have a pragmatic view on all things electronic, just like here. There are a few threads in the RME ADI-2 fs DAC section of their forum which don't so much discuss this point but tell you quite definitively what the answer is and why. I'll not repeat the detail here, (it is worth a read) but it is the stock PSU.Dear @amirm :
There is little (nothing) left for improvement on that side.
I tried a battery power once, and no difference at all on measurements.
Have a big tube mono blocks system and I tried an external battery.
It made a shocking difference but my system is very sensitive so any change will produce an audible change.
Typically the best changes are found with certain NOS tubes.
Then there's the upgrade in the firmware: from 35/35 to 66/41. It's an unreal improvement for a mere download.
RME is the bomb!
Yeah, I'm in the right place. This is where I wrote my findings. Enjoy!Hard to take serious. You sure you're on the right forum?
You can share, but that isn't enough to convince anyone.I'm sharing my experience. You got a problem with it, come see me.
Measure your "big tube", before and after whatever change you made.
A battery makes very little sense here. The biggest improvement you could make would be a good switching power supply (and actively regulating the heaters).Have a big tube mono blocks system and I tried an external battery.
It’s not the size of the tube that counts.
I'm sure that anyone reading this is curious about how the "one of a kind monoblock" measures.I'm not measuring any one tube. My friend who designed these one of a kind monoblock tube amps from an Allen Organ C3 architecture has all that measuring equipment, sheer loads of it. I'm not going to be adding this "big tube" request to the list.
Who is convinced or not is of no consequence to me.
Hi @MC_RME or @amirm
Can you do the same measurement as per the slide below, with your ADI-2 DAC ?
Rob Watts says his current DACs are the only ones in the world with no measurable noise floor modulation (below is his Hugo TT2 measured with his own APx555b)
Would be really nice to show him he is not correct
Hugo TT 2 by Chord Electronics - The Official Thread
I used to think DAC/amp that measures incredibly well would equal sterile and analytical sound, obviously not the case with Chord. Yes using traditional measurements there is truth in that observation. If you reduce 2nd harmonic distortion, and reduce higher order harmonics, things sound...www.head-fi.org
You have to understand, that subjective impressions are meaningless without being backed up by data.
