Revolution! Gradient Revolutions!
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Our new Gradient of Finland active ‘Revolution ‘loudspeakers have arrived!
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Gradient of Finland ‘Revolutions are assembled ,this pair is their ‘active’ version , the amplifiers and crossovers are in a separate unit, four pole ‘speakon’ connectors run to each speaker , two inputs to the SW ( sub woofers) and two to the main speaker.
The Revolutions have dipole ( figure of eight ) radiation, allowing the bass units to be turned to minimise standing wave interaction.
The head unit is a coaxial mid/tweeter with a cardioid response, similar to their latest Gradient 1.4 model.
b1daly
Holy moly they look out there! What is the purpose of having a dipole woofer perpendicular to the other drivers?
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
The dipole allows you to experiment with placement, from the traditional, woofers/mid facing, in narrow rooms you can have the mid facing but the woofers facing the rear wall ( and hence the side walls ) you can even have the woofers facing the side walls ( not the same ratio though) you can even position for an L shaped room, bass is also adjustable via a trim pot on the amp.
http://www.gradient.fi/en/loudspeakers/5-gradient-revolution.html
( can ask Gradient to send you the manual which lists and pictures all the available positioning if you are interested .
HoJ76
al2002
Can you ask Gradient if they have any plans to resume production of the SW-57 and SW-63 woofers for the Quad? There is still a fair bit of demand for those based on how fast used examples sell when advertised.
Edit: If Gradient are production capacity limited, why not suggest that they sell construction plans so that Quad owners can DIY?
