derp1n
- Joined
- May 28, 2018
- Messages
- 479
- Likes
- 629
This flaw wouldn't be observed unless the unit was taken apart and heatsinks removed. Not something commonly done. I wouldn't have removed them if it hadn't been installed lopsided in the first place.
I'm thankful no damage was done, but my DX7S is relatively new and I have not been using the headamp section - just DAC only mode. I've never seen a heatsink used without TIM before Topping.
A heatsink will work without a special TIM, it's just less efficient. TIM is not always used or needed.
Both of the packages are also sinking heat into the PCB via the metal tabs on the voltage regulators and pads below the op amps. So the top heat sinks are nice, but perhaps not essential. Other devices using those parts have been manufactured without additional heatsinks attached.
The chance of damage is basically zero. You seem to be overstating a pretty minor thing based on misunderstanding.
