Note that EMS is also considered express/courier.
Ohh, well we will see, from what I have seen EMS is cheaper than those other guys. I will ask. thanks for letting me know.
In many cases EMS is mostly the same as free shipping with tracking number, and for expensive items almost nobody will take the risk of shipping untracked.
Anyway they must only charge the amount that appeared when placing the order, that should include shipping costs, if that's not the case I would contact the seller/aliexpress.
Dear, how about SMSL panda stackNo, I would not trade one dac for the other. If you need the headphone amplifier then the DX3Pro is better since for the same price it includes that option.
I have not measured it and they have hardly any specs on it so no way to know how well it performs.Dear, how about SMSL panda stack
Thanks Amir. My current stacks are/will be D50/O2, DX7S/MD THX 789, and Monoprice THX 788 (assuming the latter gets your seal of approval).No, I would not trade one dac for the other. If you need the headphone amplifier then the DX3Pro is better since for the same price it includes that option.
I just took a look and with 300 ohm load, the O2 and DX3Pro amps are similar. At 33 ohm though the DX3Pro is much cleaner from middle to the end of its power band. If your headphone impedance is on the lower end, the DX3Pro should beat the D50/O2 combo. It is also much more convenient with a single very nice looking box.The DX3Pro would only fit as a replacement for my D50/O2 stack and it doesn't sound like that makes sense based on what you have said here...
Thank you Amir. Ordered.I just took a look and with 300 ohm load, the O2 and DX3Pro amps are similar. At 33 ohm though the DX3Pro is much cleaner from middle to the end of its power band. If your headphone impedance is on the lower end, the DX3Pro should beat the D50/O2 combo. It is also much more convenient with a single very nice looking box.
