Hi all,
I have found these forum a couple of weeks ago.
And there seems to be much knowledge here.
Now I don't know much about headphone amplifiers and such.
Soon I will have a Beyerdynamic DT-250 250 Ohm. I have calculated at digiZoid what amplifier I would need.
This came up
Fairly Loud 110 dB SPL1.45 Vrms5.4 mA7.83 mWVery Loud 115 dB SPL2.59 Vrms9.64 mA24.97 mW
Does the Topping DX3 amplifier give this power (Volt or Watt I don't know, I have read that the Beyerdynamic likes Volt)?
I also found this in another place but I don't know what it means
In a quiet environment for the Beyerdynamic DT 250 250 ohm , an amplifier with a voltage level of at least -2.74 dBV at 269 Ohms is recommended for listening to music with a level of 90 dB SPL (without noise isolation). An amplifier with a level above 35.26 dBV is not desirable if the volume control is digital, not analog.
For noisy environments, an amplifier with a voltage level of at least 9.26 dBV at a load of 268.67 ohms is desirable.
If you want to listen to music at a different volume level, you just need to add or subtract a change in dB to 90 dB SPL (for example, for a desired level of 105 dB SPL, add 15 dB and the minimum voltage level for the amplifier is -2.74 dBV + 15 dB = 12.26 dBV).
Analysis of the impedance of Beyerdynamic DT 250 250 ohm headphones
The average resistance at the headphones Beyerdynamic DT 250 250 ohm is 268.67 Ohm.
The resistance affects the amount of current that the amplifier should give to the headphones. If the current is not enough, the sound quality will deteriorate, beginning with harsh in the sound and ending with a banal rattling. In most cases, at low current values, the amplifiers operate in comparable quality to class A, and as the current level rises, the quality decreases toward AB, B, and the clipping zone.
Imagine that you have a water tank, which gradually becomes filled with water. The voltage at the amplifier, this pressure, with which the pump pumped water from the reservoir. If the inflow of water in the tank is lower than the volume that the pump pumps out, then at the pump outlet we collect water and "bubbles". Similarly, with the sound from the headphones, which lacked current from the amplifier.
For a quiet environment, an amplifier with an output current level of at least 2.71 mA in a given class of quality is desirable (preferably orientated to comparable class A) and 10.80 mA for loud.
Does this amplifier put out the right amount of power?
Sorry If these are stupid questions.
A very nice forum by the way.
