Dear users
As you discussed, some of our DX3 pro unit met a problem of "not able to turn on from standby mode". These units shows only a dot on the screen, it is able to go into setting but not able to turn on. All these units met this problem after a short time use. Now we got 10+ reports but we believe the quantity is higher than that. (Member Yue said that is 20+ units)
We got several defect unit back for analysis and now we have answers and solution.
An OP-AMP, model OPA2140 of all these problem units were dead. V+ or V- short circuit to the output. It made a high current and caused power protection so the unit is not able to turn on. In a few cases it will cause transistor dead or cause DX3 Pro output DC. All these defect units works well after replacing a new OPA2140, even after 100+ hour aging test. Basing on this point and low defect rate, we believe this is not a design flaw.
Since the OPA2140 comes from a reliable supplier, we will think more about the manufacturing process. According to our analysis, problem is most likely in inappropriate process of manual soldering for fixing SMT defect(1-2%). Because only this part is more uncontrollable, and the SMT defect rate is close to the defect rate of this issue. Manual soldering for fix is only a very small quantity and no detailed engineering records so we cannot be 100% sure that this process is the reason. But our solution covered this already.
Our solutions for new batch:
1, Improve process of manual soldering.
2, Add 100+ hour aging test before sending to sellers. 100+ hour is enough for expose the problems.
Suggestions to users who did not met this problem.
Because the problem OPA2140 will dead after a short time use(less than 30 hours). So after a long time use, we believe your unit is safe and working in good condiction. Feel free to use it.
Suggestions to users who already met this problem.
If your unit met "standby problem". No matter where you bought it, we will service directly to you. Please contact (
[email protected]) for sending the defect unit back to us, we will pay back your shipping fee so you will not lost money in this issue, after receiving it, we send you a full new unit for exchange.
I am sorry that our explanation came too late and made some users worried.
