Finally done with the LPF. Use only one set of outputs for each 4493:
The 4 orange ones are niobium oxide caps. They are placed at the four unused outputs, in case I want to connect them to the next stage again in the future.
Here is the part list:
0 ohm resistor at each four output.
For the positive output at LPF - input resistor - 249 ohm, 0.1%
LPF resister - 332 ohm, 0.1%
LPF cap - 3300pf PPS film, 2%
For the negative output at LPF - input resistor - 750 ohm, 0.1%
LPF resister - 1k ohm, 0.1%
LPF cap - 1200pf PPS film, 2%
The FC point is now around 130KHz, down from 178KHz.
LPF OP - Muses 8920
How about the sound?
Let me put it this way, originally my cheap modded ES9018K2M could easily beat the stock DX3.
Now the modded DX3 would win the ES9018 by a big margin. After running the machine for 100 hours, let the e caps settle down, I will have it do a shoot out with a twin ES9038 Pro DAC.
Now the brightness on top is gone. The bottom is full and punchy. Warm, beautiful mid. The stage is wide open, the sound is embracing you from left ear to right ear. It gives you this intimacy feel and everything is so smooth and so real. . Pin point images. The vocals are specially seductive and alive when ESS DACs tend to keep you from the singer at certain distance, and try to persuade you the singer is working hard to impressed you.
To make it simple, the modded DX3 sounds so effortless yet so dynamic at the same time. It's a very refreshing listening experience to me. Now I know why AKM calls this velvet sound.
It's amazing this thing only costs around $300 after mod. And I am still using the stock power supply!
