Thanks John as always.This is due to the limitation in the windows audio stack. You can use foobar2000 or other player to play higher sample rate files via ASIO. (although I don't think there's published 768khz music available)
Basically correct.
Windows can output 384khz. You can measure frequency response up to half of the FS. It's just everything gets resampled to the selected format.
Asio bypasses the whole stack directly talking to the driver.
D50s is actually an improved version. It is slightly better in all aspects.Hi Guys,
D50 is no longer available and has been replaced with D50s
Is D50s a better version of D50 (Improved implementation and performance) or is the same with the addition of BT?
They seem to share the same Chip and OP amp.
What's the best connection for D50s?It works better when connected to the digital source via USB or coaxial cable?
I read about problems with Spdif Input
Hi Guys,
It will accept USB.Sorry Guys I've a question
My future digital source will be an Intel Nuc mini pc that only has USB digital outputs
If I wanted to try to connect the Dac via coaxial, how would I do that?
I'd purchase an adapter?
I'd Try to experimenting How DAC will perform with Coax digital OutputIt will accept USB.
Is there a reason not to use your USB output from the NUC?
I mean Maybe the signal is more clear or maybe the sound has more DR and Wide soundstageDefine "experimenting" and "perform"?
Amazon has several options for a USB-> SPDIF coaxial converters. Not sure on performance as I’ve never tried one.I mean Maybe the signal is more clear or maybe the sound has more DR and Wide soundstage
