Only when it's measured and verified...
Hi, I do have something audible to measure and to tweak, but for the time being I don't know how, neither where... Several of my FLACs get distorded, on some of them, my loud speakers are like buzzing. And I'm wondering if it is due to the D50s (stock, no mod), my amp (Atoll MA100 used at low levels, so supposed to run at 0,05% distortion and 2us slew rate) or my speakers (Dynaudio Emit m20).
I don't get similar sounds with another speakers/amp/DAC set, DAC being there an Aune S16, but that isn't perfect either.
Next days, I'll swap out the LME49720 for a OPA1612, just to test and listen, that alternate shall have similar characteristics, but a higher slew rate (27 compared to 20). May something else be easily tried on D50s side to tweak around such sounds and effects? I'll first try to tweak on DAC side, as I have other digital electronics which behave the same, but much worther on such sounds.
Attached is a sample pattern, I found almost similar patterns in other "buzzing"/distorded FLACs. Here, a short excerpt of Fabrizio Rat, Indigo, with a double hit/buzz in the track at approx second 24. Highlighted, where I get those buzzing sounds (but many other occurences in that track, known to sound "distorded").
PS: Indigo is on Youtube, but that doesn't produce similar effects, probably due to the mp3 compression. But you will notice the double buzz at approx 24 seconds.
