Yes, fits, as should any MM and MC cartridge.Ortofon Concorde 40
BTW, welcome to ASR.
Define "best".So is this still the best Phono Preamp? I'm thinking to replace my Muffsy MP-4.
And in English?Define "best".
As per MM SINAD, it was measured for 1V output (11mV input) which is different than what Amir standardized on later (5mV input).
From the THD+N vs level plot, one may deduct around 84dB SINAD for MM at 5mV input.
So this is, anyway, excellent.
5mV input with 39dB gain gives approx. 450mV on the output.
Which measures at 0.006% THD+N or -84dB.
It compares well with the best measured here (even if it's not ranking as #1)And in English?
Thanks hahaIt compares well with the best measured here (even if it's not ranking as #1)
There is a SINAD ranking for phono preamps.Thanks haha
Is there a ranking to be found somewhere on here for phono preamps?
I'll take a look at that. Thanks!There is a SINAD ranking for phono preamps.
This doesn't tell the full story, though: you need to take into account Frequency response accuracy, gain, flexibility, distortion vs noise, headroom,...
(There are a few mistakes as well in the ranking, IMO.)
So take this ranking with a grain of salt: it should just tell you what to avoid, since they perform way lower.
It appears more or less the same in measurements.I wonder if the solo will be just as good or if the Duo is not only capable of MCs but also built better?
Thanks for this reply. I've also the possibility to buy an Atoll PH-100. Would that be a better option?It appears more or less the same in measurements.
The build quality of the Duo is fine, but nothing stunning either. It's a grey metal boy ;-).
I would go with what is cheaper to you. I got my Duo used for pocket change, wouldn't buy it for it's regular price.
By what metric?Thanks for this reply. I've also the possibility to buy an Atoll PH-100. Would that be a better option?
Is the built quality better? And with the 2M Blue cart I have, would the ATOLL be a better match sound-wise?By what metric?
Probably not.Thanks for this reply. I've also the possibility to buy an Atoll PH-100. Would that be a better option?
So I have no brand loyalty, I’m just trying to upgrade to my final one. I plan to stick with MM only, so MC isn’t a huge deal. No Headphone amp needed. My main concerns are best performance under say $300, and hoping that I can get one that isn’t too wide due to placement. I would highly prefer one with a rumble filter.Define "best".
Which measures around 0.006%-0.007% THD+N or -84dB to -83dB.
FR +/-0.65dB, that isn't a "real" problem i believe.What do you guys think?
