Veri
- Joined
- Feb 6, 2018
- Messages
- 9,599
- Likes
- 12,041
TouchéDon't shoot the messenger lol.
Audio gd don't claim good measurements they claim good sound so what's the goal of making a review to say that it measures bad without even trying to see if indeed it sounds good?If you want subjective reviews there's tons of websites such as HeadFi that you might wanna check.
Yes you want to believe in that.I think that's called confirmation bias, something we all suffer from.
I think you are looking at wrong thing. HATS can simulate both directions - sending (mouth) and receiving (ear). Quoted graphs shows performance of mouth (used for testing of headset micropohone for example), not ear. It is stated at title of table "Maximum harmonic distortion of HATS mouth".Not worried about his electronics. That, we know is great. The worry is about his measurement mic. He is using the Head Acoustics HMSII.3. This is the spec for that: https://www.head-acoustics.com/downloads/eng/hms_II/D1230_HMS_II_3_e.pdf
And 2nd harmonic alone versus frequency:
As you see, SINAD is as low as 28 dB at 50 Hz. And only climbs up to 65 dB or so. A perfect headphone would measure like the above graph.
ITU-T P.58 by the way is highly permissive in this regard as you can tell from above graph:
These fixtures are designed for other characteristics than pure distortion measurements. The requirement for low distortion is to make sure it doesn't interfere with other measurements.
There is ignore button just fyi.Where is the dislike button?
Honestly, ASR is about true fidelity and not about nice sounding equipment. If I want to manipulate the sound I use my Behringer Ultrafex Pro or the tone controls in my AV processor (which I do for bad recordings), but I expect my hardware to put out what is put in with as low THD and noise as possible.
Feedback sounding bad is a myth. Just because somewhere in the 70ies one or two power amps were designed so badly that the feedback was too high and made them sound worse doesn't mean that feedback as such is bad. Actually feedback, if properly designed, makes everything better.
Wrong. Their website is full of measurements and they claim using an Audio Precision. "good sound" is not a measurable value here. I suggest you to check SBAF instead.Audio gd don't claim good measurements they claim good sound
100% agree! Nothing says AGD units will get better in the future for some reasons.Firstly, I don't think banning audiogd future measurement is a good idea. We should be open about companies and manufacturers. Not because it measures bad, we just ban them. That's irrelevant.
That's indeed a big problem.They especially is problematic. They are now trying to appeal to those who think products should be tested, cfr. ASR movement.
But so far, their advertised specs have not even once matched what Amir measured iirc...
Just add some EQ effects to your music ir order to please you. That's fine.@Duckeenie
@amirm
ASR should be more rigorous and confirm that the audio gd dac don't sound better by validating with a blind test.
If not you re biased like the audiophiles.
And then for us readers who want the truth we don't know who to trust.
Neither scientists neither audiophiles do blind test.
You re all in the same bias and not open minded.
Rtings is another good site:Show me a trustworthy distortion measurement for headphones
This is an assertion without evidence. I'm inclined to beleive you may be at least part right but it's almost impossible to prove.Placebo based effects work this way. Since they are based on one's mindset and not auditory input, when that mindset changes in the future, so does impression of said gear. You want to know why high-end audiophiles keep changing gear? This is the main reason.
I just knew the review following best measuring device yet would be fun.
Not sure how exciting this place will be when multiple devices exceed measurement capability into excellence. Well, a couple iFi's buzzing around a pile of Schitt might get some cheap laughs.
Seriously though, is there a contingency plan?
What a shame. It is still worth bearing in mind that it is doubtful that anyone will hear a difference between this and a better measuring dac.
For me the problem is I can buy a far better measuring dac for a quarter of the price. Still, it does come in black which makes an awful lot of difference to how it would sound to my ears.
I'm kind of partial to the black ones. I hear a much greater depth in the lower bass regions and that digital type glare one associates with silver boxes just isn't there with the darker colours. Of course, the finish of the black is critical. It's one of the reasons I like my Exposure amplifiers.......they're just sooooooooo smooth and this gives deep base that liquid quality silver just can't match, no matter what the finish.LOOL So, which DAC sounds better, silver or black?
